Blinkers blinking slowly....
Old Jun 27, 2006 | 06:38 PM
SLIKWS6's Avatar
Default Blinkers blinking slowly....
and then they come to a stop and then go up again.
Some have said the more horsepower you have the slower theyll be, thats why you always see others with fast *** blinking lights.
Anyways anybody know whats going on.
Thanks
Old Jun 27, 2006 | 07:07 PM
2001FireBird's Avatar
Perhaps a bad alternator? Do you have anything that could be draining a lot of power, IE a system? I've a similar condition, but its at idle only. While playing my system my voltage drops below 12.4, lights dim and the blinker of course slows. I'd have to place light throttle to get the alt to spin a lil more to raise the voltage, and once it reaches around 13v everything works correctly.
I dont know about the fast blinking lights being associated with high gains of HP, it'd be news to me if it were true. Usually from what I see, the people who change the pace of their blinkers could be part of that Fast&Furios hype. More of an appereance thingy to me.
Old Jun 27, 2006 | 08:46 PM
MIKE_84's Avatar
probably the flasher
Old Jun 27, 2006 | 09:24 PM
BigSteele's Avatar
funny thought, but its probably the flasher unit/relay whatever. I think they work by a metal strip that makes contact, heats up and bends, then contacts another piece, then cools, and moves back to the first part where it will heat up again and repeat. If you can understand my description...
not sure where the thing is at but put on the flasher and listen to find out.
Im sure they make different delay speeds to suit your hp taste
Old Jun 27, 2006 | 09:44 PM
Hugger Z's Avatar
It is your flasher module. I think it is a round silver thing on one of the fuse blocks. Mine did the same thing where the blinker was really slow. That was back when I still had the factory warranty so the dealer replaced the flasher relay and all is well. Should be an easy fix.
Old Jul 6, 2006 | 08:18 PM
SLIKWS6's Avatar
Thanks for the feedback, I have yet to look into it as I havent' had time so I'll check it out now, thanks again.
Old Jul 6, 2006 | 09:02 PM
SLIKWS6's Avatar
Could you give me some more info on the location of the module, I just looked at all fuse blocks and could not find the specific one. The larger fuses were gray and of the brand omron.
Old Jul 6, 2006 | 09:56 PM
MikeFbody's Avatar
Restricted User
it's under the dash, on the driver side. You need to drop the black plastic panel near the pedals, as well as the knee bolster part. You should find 2 round metal flashers. One is for blinkers, one is for hazards, but me memory of which is which has escaped me right now.
mike
Old Jul 6, 2006 | 10:59 PM
Renegade's Avatar
mike
Yep, I second the flasher theory... had this problem on my last car, replaced flasher and everything worked fine again. It's really easy to install, but if it doesn't work the first time, take the flasher back and replace it with another and try again. I've heard of that happening before, just because it's a new flasher doesn't mean it's gonna work. Good Luck :-).
Old Jul 7, 2006 | 07:12 AM
WhiteBird00's Avatar
Ungrounded Moderator
The turn signal flasher is clipped to the underside of the dash just to the right of the opening when you remove the plastic knee panel under the steering column. The hazard flasher is on the left side.
Old Oct 15, 2006 | 03:47 PM
flyinglow57's Avatar
can you swap the hazard flasher for the turn flasher? just so i have turn signals? cause its the steeler game and we dont leavethe house to get parts
Old Oct 15, 2006 | 04:21 PM
Yes you can - if that is the problem. It is unusual for the flasher to die because it's a very simple device. The most common problem is one side flashing but the other doesn't. This is caused by a burned out bulb or corroded bulb socket on the side that doesn't flash.
Old Oct 15, 2006 | 06:11 PM
swaped hazard/turn flasher... now i have turns no 4-ways though. good enough for now... thanks everyone. oh yeah go steelers
