Horible radio reception: advice needed
Hey guys. Ive searched and found many of you have put in aftermarket decks and had poor radio reception afterwards. I had a 10 year old Pioneer CD player in and it worked great. Upgraded to an Alpine deck this year and now my reception sucks. Ive checked the connection at the deck and it seems good. Im running 3 RCA cables, remote and speaker wires on the antenna side of the car. Power and ground on the other side. Anybody have a clue? It seems that guys with Alpines have this problem more than most. I have the same deck in my truck and it works very well. Thanks.
did you hook up the power antenna? if its not hooked up or not working correctly it will kill your reception.....also factory decks will always get better reception that aftermarket....in fact you usally dont even pick up AM on an aftermarket. so you can count on a little reception loss but if its bad to where it seems like the antenna is disconnected....make sure you have a good connection, plus you have an antenna adapter make sure its good, and you wont need a noise filter......thats if you have engine noise. if your having poor reception it is due to the antenna or the head unit....i have installed a few decks before that just came that way out of the box and we had to swap it out for another one and it fixed the problem.....but that was also on a less than par brand deck. but anyways there is some advice.
no a head unit can definatly pick up engine noise if installed incorrectly......but, if he is having a problem with reception then engine noise is not the problem. thats all i was saying
