shorted left turn signal?
Any help in any of this would be very appreciated.
A common problem with turn signals on our cars is where one side will flash properly but the other side only goes on solid. If this is the problem then you have a burned out bulb or a corroded socket (most likely at the front because of the way they get water in them). The easy way to find this is to turn on the hazard flashers and then walk around the car looking for the bulb that doesn't flash.
When you say the parking lights flash with your turn signals do you mean all the parking lights on both sides? Because if there were to be a short between the two unrelated systems then it would affect all the lights not just those on one side. However, if you have a Camaro and the just the tail light on the same side as the turn signal is lighting up then you probably have a bad ground at that location causing the turn signal current to seek ground through the parking light bulb.
I'm just guessing at this point. If you post more details we can work on diagnosing the problem.
I have a 2000 Trans-Am LS1 with fog lights.
As I see the schematic in the Haynes manual, it appears that there is a seperate switch relay for each turn signal and one for the hazard, but I suppose that I have to be reading it wrong because there are too many people (like yourself) that advise me to the contrary. So I suppose that isnt it.
Now, when I signal left, all the lights and filaments go on exept for the headlamps themselves.
If I turn on headlights/parking lights, the left signal lights light up (no flashing).
I did (at one point) remove all lights in the rear, and the problems continued.
I removed the rear lights fuse and the problem stopped.
I have some time today to look at it, so I'll keep you posted.
Thanks.
Thanks.
From your description it sounds like there is something wrong with the left front signal socket or bulb that is back-feeding current from the turn signals into the parking light system. As an experiment I would try removing the front left bulb and see if the problem stops. Of course the left side won't flash with the bulb removed but it will give an indication of whether that's the source of the parking lights problem.
The front bulb filaments were shorted together and carrying the 2nd circuit through the bulb. I really would have thaught that if this happened, the bulb would burn out. Thanks a bunch boys.
By the way, were exactly is the actual relay, in the column? It sounds (by your description) like a smaller chip.
The relays in the DRL are to control switching the front lights between daytime running lights and turn signals as necessary. If you're looking for what makes the signals flash (and makes the clicking noise) then that's the flasher. It's clipped to the back side of the dash to the right of the opening when you remove the knee panel under the steering column.
