QTP switch... what are other options?
Old Sep 10, 2002 | 06:41 AM
Biochem's Avatar
Default QTP switch... what are other options?
That's one heck of a switch that comes with the QTP cutout... but is there anything that is a little more "low profile" that works the same? Just curious...
Old Sep 10, 2002 | 07:17 AM
MY99TAWS6's Avatar
Default Re: QTP switch... what are other options?
Yeah its on huge switch!!! I had my slp fan switch in my ashtray and it woudn't fit in there anymore so put the quick time in there instead..had to get a new ashtray as the hole for my fan switch was a lot bigger than the quick time switch hole..it was like 10 bucks US so not bad.I might make a plate for the ashtray area later on,think that might let me mount the three things I want to in there..quick time,slp fan switch and some kind of line lock.Planning on nos but getting nx switch panel for that.fits neatly in the area next to the lighter.
Old Sep 10, 2002 | 09:37 AM
dan98z's Avatar
Just mount it here where I did:
(might have to copy and paste the link)
http://dan98z.hostmb.com/mounted.jpg
From the driver seat you can barely see the switch with your eye, and it is totally out of sight from the passengers seat. Took all of 5 mins to drill a small hole in the back of that plastic thing, feed the wires in and tap a 12v line to power it. Haven't had any problems since and it stays in place really good.
also check out comparison between qtec and mccord in my post, you will see which is of greater quality.
http://dan98z.hostmb.com/cutouts.html
Hope this helps
Old Mar 22, 2003 | 03:55 PM
Scalpel's Avatar
I'd like a better, lower profile switch, also! (for the QTP cutout)
Old Mar 22, 2003 | 09:05 PM
DrMilhouse's Avatar
Isn't this just like any other toggle switch? Check out partsexpress.com or radioshack and you should be able to pick up a pretty decent simple toggle or push on/off switch that would do the same thing.
Sorry to be so ignorant, but what is QTP?
Old Mar 22, 2003 | 09:59 PM
Archdog7564's Avatar
i put mine under the steering wheel on the right side, it is completly out of site from both sides. i may move it to the above the ash tray and get the convertible plate and mount the switch there, and then i could put other switches on there too and it will look semi stock
qtec is a great product, Quick Time Peroformance, Quick Time Electric Cutout
if any questions, ask away
Old Mar 24, 2003 | 05:18 PM
jimmyblue's Avatar
Moderator
WOT switch and maybe a relay, if need be?
No passenger compartment switches at all.
Old Mar 25, 2003 | 11:56 AM
Scalpel's Avatar
It's a Momentary Switch. Any momentary switch will work. Thanks
Old Mar 25, 2003 | 02:53 PM
NTMID8's Avatar
I'm going to use a factory conv.top switch for mine.
Old Mar 25, 2003 | 06:25 PM
Biochem's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CANNIBAL:
<strong> I'd like a better, lower profile switch, also! (for the QTP cutout) </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Dude, this thread was started 6 1/2 months ago... start your own thread :finger: <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 28, 2003 | 07:46 AM
Scalpel's Avatar
I soldered the wires to the male prongs and it made it MUCH easier to fit the switch in the ashtray. Fits perfectly now. No more clearance issues.
Old Mar 31, 2003 | 12:43 AM
swandogg25's Avatar
I have the convertible switch on my MPP2. Everyone told me it wasn't possible to put the switch where I did, I never wanted to believe them. I was out to prove wrong. As you can see from the pic, it looks alot better than your ashtray or center console being used up. I like the complete stock look of it.
It is the gray switch next to the foglight switch.
<img src="http://home.attbi.com/~swandogg2/SS/DSC00007-1.JPG" alt=" - " />
Old Mar 31, 2003 | 08:50 AM
SMOKINV8's Avatar
Swan- Why did you even bother putting a convertible switch up there? A TCS switch is/does the same thing, and is designed to fit right in there.
Old Mar 31, 2003 | 01:29 PM
Scalpel's Avatar
TCS switch is not a momentary switch. It's simply a toggle switch. That will not work.
