Would this woofer work in our cars?
Old 12-08-2002, 04:49 PM
Tim98TA's Avatar
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Default Would this woofer work in our cars?
I need to replace both of my subs in the sail panels. I came acroos this speaker for a decent price. I know it isn't a dual voice coil speaker, but would it work just as well? Could I just 'plug-n-play'?
<img src="http://pix.crutchfield.com/products/2002/575/l575RFP3406-o.jpeg" alt=" - " />
Key Features:
* FIBERLock woofer cone
* large roll foam surround
* CONsealer gasket hides mounting screws and provides an airtight seal
* dual-laminated flat spider for maximum linear control of the cone's travel
* 25-ounce magnet
* 1-3/4" voice coil with aluminum former
* frequency response 58-250 Hz
* power range 30-150 watts RMS
* peak power handling 300 watts
* sensitivity 86 dB SPL
* 4-ohm impedance
* top-mount depth 2-7/16"
* sealed box volume 0.1-0.3 cu. ft.
* ported box volume 0.3-0.5 cu. ft. (not suitable for free-air use)
* 1-year warranty
Tim
Old 12-08-2002, 07:35 PM
SuperSound99SS's Avatar
Default Re: Would this woofer work in our cars?
i wouldn't think so...is it a 6.5"?
Old 12-08-2002, 07:37 PM
Tim98TA's Avatar
6 3/4
Old 12-08-2002, 09:01 PM
stavman's Avatar
"* ported box volume 0.3-0.5 cu. ft. (not suitable for free-air use)"
It wouldn't work unless you built a box for it. It wasn't designed for IB(free air) set-ups.
Old 12-08-2002, 10:43 PM
Shady93z's Avatar
You need a dual voice coil speaker because the stock speaker is dual voice coil and each coil has separate amplification. So if you put a single voice coil speaker in there it will only get half the power and you can not twist the positives and negatives together. Image Dynamics makes a good dual voice coil IDQ-6 and so does SAS Bazooka.
Old 12-09-2002, 07:16 AM
Tim98TA's Avatar
Thanks for the help guys. I'll check into those 2 speakers. SAS factory is located ~1 mile from me so I'll give them a shout.
Tim
Old 12-09-2002, 01:20 PM
stavman's Avatar
your not going to run this off of the stock monsoon amp are you?
Old 12-10-2002, 07:12 AM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stavman:
<strong>your not going to run this off of the stock monsoon amp are you?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah,,,,, why not? I don't need/want any hi $$$ speaker, just a relaible replacement.
Tim
Old 12-10-2002, 07:27 AM
99ragtopSS's Avatar
Tim, if you are going to replace the factory speakers and you have a monsoon then you have to go back with factory speakers. The speed volume adjustment gives the factory speakers variable watts depending on speed. If you replace with aftermarket then they will sound like crap.
In other words with a factory system your stuck. I replaced my head unit and added new speakers throughout.
If you replaced the speakers get the 6 1/2 for the rear panels and 6 3/4 for the fronts.
Old 12-10-2002, 04:04 PM
Copy & Paste Moderator
VIP1's Avatar
Which Monsoon systems have speed sensitive volume?
I have a 2001 Formula and It doesn't have speed sensitive volume.
--VIP1
Old 12-10-2002, 08:35 PM
Shady93z's Avatar
I have changed alot of them out with the SAS Bazooka speakers or the Image Dynamics and have had nothing but a bunch of satisfied customers.
Old 12-11-2002, 04:57 PM
99TranTrany's Avatar
my moonsoon doesnt have a speed sensitive volume on it.I didnt know any T/As or camaros did.?
Old 12-11-2002, 05:35 PM
Tom the roofer's Avatar
Tim, I have been reading this post for 3 days now and I got to tell you man.
It's ROOFER not WOOFER. <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> You guys talk real funny down there <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
EDIT: No, this woofer would not work in your car <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Tom the woofer <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ December 11, 2002, 05:40 PM: Message edited by: Tom the roofer ]</small>
Old 12-12-2002, 07:15 AM
Tim98TA's Avatar
The Monsoons DO NOT have speed sensing volume.
Shady93z, do you happen to have any model #'s for these speakers? Thanks
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tom the roofer:
<strong>It's ROOFER not WOOFER. <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> You guys talk real funny down there <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Tom the woofer <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah, but Tom, ya'll talk with accents!!!!! <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Tim
Old 12-12-2002, 11:17 AM
Administrator
unit213's Avatar
Are you guys referring to speed controlled volume (SCV)? My monsoon system has it. It sucks and I keep it off, but it has it.
Old 12-12-2002, 11:23 AM
ZippyZ28's Avatar
arnt the monsoon speakers 2ohms ?
Old 12-13-2002, 11:50 AM
navyz28's Avatar
Tim, if you just want good and real good speakers to go with the stock or mosson system go here to speakers and put in the year and model of your car and they will tell you what will and will NOT work with your system.... then you can go to ebay and find them cheap or buy them from this site, <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
hope this helps ya out some. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Old 12-13-2002, 11:54 AM
navyz28's Avatar
sorry link did not work here try this one 2nd chance
Old 12-14-2002, 12:09 AM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by navyz28:
<strong>Tim, if you just want good and real good speakers to go with the stock or mosson system go here to speakers and put in the year and model of your car and they will tell you what will and will NOT work with your system.... then you can go to ebay and find them cheap or buy them from this site, <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
hope this helps ya out some. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Which site is it? The link is not valid.
Tim
Old 12-14-2002, 12:44 AM
navyz28's Avatar
sorry Tim go to www.crutchfield.com, under the home page their is a tab for speakers and sub woofers, under that page you can pick your car and system and a list of what will work....
i just got a complet set of speakers and a MTX 10" sub for my ride, it came out so so sweet, will have pick soon sunday i hope will post when i get them uploaded. <img border="0" alt="[Z06 Corvette]" title="" src="graemlins/z06.gif" />
