What is the B-E-S-T sound deadener?
This may be the wrong section, but I don't know where else to post it. I am not looking to keep sound in, looking to keep it out. Right now my car has no carpet. I had a t-top leak and it made my car smell like 3 day old cat **** wrapped in boiled cabbage. Anyways, I am getting my center console fiberglassed and would like to get the carpet in before I get the console back. Needless to say, I want to put in a good sound deadener underneath the carpet. I run open dumps under the car and daily drive it with a 4400 stall (think 2800rpms at 30mph EVERYWHERE). I am not planning on changing it; I love the way it sounds out of the car but I can not even hear my radio.
Soooo, what is the best sound deadener out there? I do NOT want to get a spray in kind, I would like something I could take out if I ever decide to go a different route. Weight doesn't really matter all that much, the planned engine should be able to handle an extra 100-200lbs no problem
I wouldn't mind buying it online if a sponsor carries it or if somewhere else has some for a good deal. PM me if your links aren't allowed. Thanks
Second Skin is the best product as far as heat resistance and adhesive, and thier standard product is thicker than either of the other two options...
But yeah, the order would be:
Second Skin Damplifier Pro
Dynamat Xtreme
RAAMaudio RAAMmat BXT
In that order...
In order of price (lowest/best value to highest):
Dynamat Xtreme
And, at the moment, that is the top of the list in products out there...
As a side note, I just got done ordering almost $500 of sound deadening product for my car, thus I just got done with all the research... I ended up going with Damplifier...
Dynamat Xtreme
In that order...
Dynamat Xtreme
Originally Posted by Mike02Z
I just ordered a boat load of eDead v1. Over at one of the vette forums guys swear by that stuff and it was cheap compared to Dynamat.
The doors are the closest active area to your ears and work in tandem with that big piece of door glass right by your noggin, as well as housing your front drivers. The rear wheel wells are the largest area for tire/road noise transmission, because there is only one panel between you and that rumbling tire.
Cruising down the road most of what you hear can be attributed directly to these two areas, thus they are taregeted first.
From there move onto the hatch well and floor, lid, then crazier areas like the firewall.
It's not so much that the floor doesn't matter, it's a bang for the buck type of thing. How much deadener area required for a given benefit. That's why people start with the doors and rear wells.
I'm in the process of installing Second Skin's Damplifier in my 94Z right now.
It took 78 sq ft to cover from the taillights to the gas pedal. Keep in mind it's a convertible, so the rear seat only goes up speaker-high (otherwise I would've continued up the panel to the roof). That includes the trunk well, the spare tire well, etc. I doubled up in a couple of spots that had a pronounced drum effect - behind the rear seat, and on the trans tunnel at the rear of the console area. I just started doing the drivers' side door yesterday, I'm about 6 sq ft in to it so far. I bought a total of 160 sq ft, hopefully that'll be sufficent for the 'vert.
I decided on Second Skin because it's not asphalt based. There's no smell to it. It's not the cheapest, but it's not the most expensive either. I know I could have done roofing peel-n-seal or something cheap from Home Depot... but I don't want that crap in my car.
Dynamat Extreme and the spray on Dynamat are the only stuff I ever use works great but once its on dont ever plan on taking it off. Used them on everything from beat up Chevys to Ferraris always worked out great when installed properly.
Dynamat extreme is my first choice so far.
Second Skin Damplifier Pro might have better white paper specs but until I see many people winning the competitions with them, they don't mean anything to me. Everyone's been trying to beat Dynamat for the past 10 years. The've been on top for a long time.
