hardwiring radar detector
Old Nov 14, 2006 | 06:14 PM
98hardtopZ's Avatar
Default hardwiring radar detector
guys i need help, i got a radar detector and right now its just sitting on my dash pad hardwired with my cdplayer. i want to windsheild mount it on the drivers side right next to the rearview mirror, you guys know how i can hardwire into the rearview? i turned it as far as i can and i can see the three wires going to it but i cant figure out how to unplug it and i dont want to break it. i can tap into those but having them loose from the mirror would be 10x easier. also, they arent red/black/white, there white, blue, and some other color i dont remember. anybody know whats positive/neg without me having to test em?
Old Nov 14, 2006 | 08:17 PM
WhiteBird00's Avatar
Ungrounded Moderator
Do not use the wires at the mirror unless you want to have to remember to turn off your detector every time you leave the car. The wires are for the courtesy/map lights and are hot at all times (battery feed). Run your own wires down the A pillar to the fuse panel.
Old Nov 14, 2006 | 08:44 PM
98hardtopZ's Avatar
i tried that, i started from the end where i wanted it by the mirror and ran it under the headliner and made it to the apillar, from here i was befuddled as to how in the hell to get it under that pillar, i tried prying a little but didnt want to break something so i said the hell with it for now, its dark...do you have any pics of your setup?
Old Nov 14, 2006 | 09:38 PM
NoTicketsPlease's Avatar
i ran mine down the a pillar. sorry i dont remember the details but i didnt have much trouble with it.
Old Nov 14, 2006 | 09:58 PM
Formula350's Avatar
Why would you put it in such a craptacular spot like up against the A-Pilar o_0 Dont want it to work right? lol The Fuse panel is right there, why dont you run the wire into it heh Quite easy IMO. Just run it to the radio slot.
Old Nov 14, 2006 | 10:19 PM
SLVR_99-Z's Avatar
its not going to matter much if the detector is on all the time. i have mine plugged into my accessory outlet because i haven't had the chance to hardwire it yet and that is always hot. i can leave it on for days with no problems.
Old Nov 14, 2006 | 10:37 PM
98hardtopZ's Avatar
what are you talking about? i wanted it on my side (driver's side) of the rear view mirror? right now its sitting on my dash right above center a/c vents...
Old Nov 15, 2006 | 06:53 AM
It's not too difficult to remove the A pillar trim. If you don't have t-tops then you can just pull it off. If you have t-tops then you have to take off the t-top and remove the two screws at the top of the pillar trim before you can pull the trim off.
That's true but why would you want to if you don't have to? It only takes a few minutes extra to do it properly.
Old Nov 15, 2006 | 03:37 PM
jimmyblue's Avatar
Moderator
I wired to the mirror and on mine the hot wire I used,
is part of the "retained power" circuit and goes to
sleep after a while. So it's OK to sit for a week at
the airport etc. The downside is, door / lock activity
makes the detector go through it's boot-up boogie
every time with all the hooting and whistling, when
that circuit gets bounced.
Old Nov 15, 2006 | 05:07 PM
98hardtopZ's Avatar
so the a pillar trim just comes off? so just tug on that sumnabitch until it comes?
Old Nov 15, 2006 | 07:21 PM
Yup, without t-tops the trim is just held on with S clips - just pry it off.
Old Nov 16, 2006 | 12:59 AM
98hardtopZ's Avatar
ima go yank on it and wire that sucker then, ill post up pics in appearance just for the hell of it..
