Brighter headlights on Firebird
Old Jan 1, 2007 | 11:52 AM
02NBMFormula's Avatar
Default Brighter headlights on Firebird
Currently the headlights on the bird arent very bright compared to other cars ive been in. so i would like to upgrade the bulbs so they are brighter and i can see better at night. what are my options. yes ive searched. thanks in advance.
peace
Old Jan 1, 2007 | 12:49 PM
351mach's Avatar
I'd say basically your two options are a better stock bulb such as the Sylvania Silverstar or step right up to an HID system.
Old Jan 1, 2007 | 01:31 PM
firebird5134's Avatar
A good start would be to do the silverstar conversion. Currently they dont make silverstar sealed beam lights so you have to make your own housing. Its a sticky somewhere on this site. You can also buy the housings already made for around $40 online. Like 351 said you could also go straight up to HID's but they're usually around the $300 range and you still have to do the housing conversion.
Old Jan 2, 2007 | 01:03 AM
Transamin00's Avatar
Old Jan 2, 2007 | 01:44 AM
pHEnomIC's Avatar
How much does a full set hid conversion like that cost?
Old Jan 2, 2007 | 08:32 AM
kits were 150 for each 2 kits, one for high one for low.
then 20 bucks for new housings, i took apart sylvania replacements and stuck in HID bulbs. so total.... roughly $380
Old Jan 2, 2007 | 09:08 AM
VIP1's Avatar
Copy & Paste Moderator
Just a few threads on the subject:
*** https://ls1tech.com/forums/appearance-detailing/491749-ls1-firebird-headlight-upgrades-general-guide.html
*** https://ls1tech.com/forums/appearance-detailing/620634-firebird-projector-headlights.html
*** https://ls1tech.com/forums/appearance-detailing/623222-ok-what-s-best-hid-s-out-there.html
*** https://ls1tech.com/forums/showpost....76&postcount=5
*** https://ls1tech.com/forums/appearance-detailing/609808-re-did-my-headlights-h7-bulbs.html
https://ls1tech.com/forums/appearance-detailing/624972-serious-discussion-hids-long.html
https://ls1tech.com/forums/appearance-detailing/619692-cleartrans-am-headlight-assmbly.html
https://ls1tech.com/forums/appearance-detailing/426616-t-hawk-hids-pics.html
https://ls1tech.com/forums/appearance-detailing/615280-headlight-conversions.html
https://ls1tech.com/forums/appearance-detailing/614801-hid-s-question-retro-fitting.html
https://ls1tech.com/forums/appearance-detailing/605499-another-headlight-brights-question.html
https://ls1tech.com/forums/appearance-detailing/609319-i-bought-some-new-h4-light-my-firebird-they-i-cant-put-them.html
https://ls1tech.com/forums/appearance-detailing/609500-h4-h7-bulbs.html
https://ls1tech.com/forums/appearance-detailing/605521-brighter-bulb.html
https://ls1tech.com/forums/appearance-detailing/580599-t-hids-installed.html
https://ls1tech.com/forums/appearance-detailing/569488-need-help-headlight-conversion-95-firebird.html
https://ls1tech.com/forums/wiring-stereo-electronics/572716-trans-am-headlight-bulbs.html
https://ls1tech.com/forums/appearance-detailing/570971-t-halos.html
https://ls1tech.com/forums/appearance-detailing/566308-clear-head-lamps-trans-am.html
https://ls1tech.com/forums/showthread.php?t=569488
https://ls1tech.com/forums/pontiac-firebird-1967-2002/551076-trans-am-headlights.html
www.ledgauges.com
Old Jan 3, 2007 | 03:33 AM
Formula350's Avatar
They used to, unless you mean for a Firebird, then it depends on the year. I'm pretty confident they have them for the single style. If not you can always get those kits on eBay to convert to capsule design. Friend did that in his 94 Vette, which I think is the same as early 4th Gen.
The Sylvania Extravision, or whatever they're called, are VERY bright yellow (standard) light. I might get those for mine instead of Silverstars.
Old Jan 3, 2007 | 09:29 AM
_JB_'s Avatar
Convert all the lights to hibeams lol
Old Aug 4, 2007 | 03:55 PM
toplessHO's Avatar
Im currently doing projector HIDs in my 97.
Not easy but will be worth it.
Im now using Hella H4s in Hella housings and Hella FF50s for driving lights
wired for Highs only .
Ill keep the FF50s and be using GM Bi-xenons in place of the sealed beams.
Yes it costs more than the kits.
But I wont be blinding anyone either.
Old Aug 4, 2007 | 05:09 PM
Ten32's Avatar
If you do the Silverstar conversion, will the H4 bulb fit in the plug already in the Firebird or does that need to be replaced?
Old Aug 4, 2007 | 07:24 PM
aliensRreal's Avatar
Originally Posted by VIP1
That stuff looks amazing! Wish I had the cash to do headlights, gauges, and radio (if they had the firebird radio on there.)
Old Aug 4, 2007 | 07:28 PM
Blacker's Avatar
The HID's were well worth the cost. I can see much better over the stock Halogens.
Old Aug 4, 2007 | 08:31 PM
VIP1's Avatar
Check out the Lighting FAQ:
https://ls1tech.com/forums/appearance-detailing/710357-lighting-faq.html
(Its in the "Hall of Fame" sticky in the "Appearance & Detailing" section.)
Old Aug 8, 2007 | 02:46 AM
Ten32's Avatar
Anyone? Couldn't find it in FAQ.
Old Aug 8, 2007 | 07:02 PM
VIP1's Avatar
At one point I made my own conversion housings to fit a H7 bulb into a 4703 housing, but it eventually filled with water and a loose connection melted the stock connector.
Here is a thread where I talk about it:
https://ls1tech.com/forums/showthrea...hlight=housing
