High Output Alternator
I use a Powermaster 150 amp. It has warranty also. Paid less than 200.00 from one of the big racing mail order companies
Horrible customer service, every alternator shipped to me was thrashed in shipping, and in the end he ripped me off of a core charge.
-B
Mike, your not the average guy. That may be why your fine on the stock alternator.
i got a 200amp from nathan. i have to admit it was shipped like crap. a single layer box with just loose packing peanuts which let it end up breaking a chunk out of the little plastic vent on the back. but other than that i've had no problems with it, lol.
(well, i did end up having to pick out some packing peanuts from inside the alt....)
i didnt want to go thru the hassle of sending it back so i went ahead and put it in. nathan did offer to swap it, but i really wanted to get the stereo done. its been good for around 2 years now with about 30k miles on it.
anyway back to idle output. at idle (900ish) at night with the lights on and playing real low stuff i cant max it without dimming, but right off idle it pops right up. stays rock solid at idle during the daytime unless i have 36mafia playin or something... (btw, i'm not a boomhead, i listen to ac/dc, rush, or sound of urchin 95% of the time, and it doesnt dim near as bad at night playin rock)
wait, whats this post about again?...
*edit* bought a new belt, a gatorback, and now even with the stereo up and heat on full, and headlights, im back up to 14volts at idle, would the belt really help out at all? strange to think that replacing the belt would give me +1volt at idle???? weird how something small seems to have a huge impact sometimes
On the other hand, others can put out big power at higher rpms and be less than stock at idle. I think the factory alternators on the LS1's put out around 35amps at idle if I remember correctly. The Alterstarts 235A unit puts out 120 amps at 800rpm. That's a huge improvement.
I think Nathans alternators kick in at 900rpm if I remember right.
I have a 6 spd car but I don't remember what the idle speed is, but I know that it can be increased simply through the computer. So if I need to set it at 800 or 900, I could. I could probably set it on the butterfly as well as I remember a set screw there.
Here's a thread with some different options.
http://www.thirdgen.org/techboard/po...13-post10.html
BOSS APPROVED!
