HELP.driver side window just sopped going up or down
yes its the motor.. go to discount auto spend 50 bucks on one and it comes with a lifetime warranty.. dont waste 20 bucks on a ebay one
If you need to replace the switch it is the part in the second picture - the first part is just the harness connector.
EDIT: If you have a 97-02 Camaro, the switch part number is 10402842 - about $16 retail.
My $ is that it's the thermal coupling (which is in the motor itself).
My suggestion is that if it is the case consider bypassing it or get a new motor. No matter what you do, use the Autotrix kit on both windows to prevent this from happening again.
