power antenna output
If you have an aftermarket head unit there will be a designated power antenna wire that may or may not be active when using CDs - it varies from make to make and even from model to model.
The system control terminal is probably what they call the remote turn-on lead for triggering an external amplifier when the head unit is on. The audio mute lead is for use with a cell phone or similar device such as a GPS) that you want to have mute the music when it produces signal. The others are input rather than output. Orange maintains the HU's memory, red turns it on with the ignition, yellow dims the display when the headlights are on, and black is the electrical ground.
You also run into a speaker wiring problem. Let's say you've got an amp that is rated 60W x 4 into 4-ohms, 90W x 4 into 2-ohms, and 180W x 2 into 4-ohms (these are not unusual numbers). Let's also assume you've replaced the Monsoon 2-ohm speakers with more common 4-ohm aftermarket speakers. The problem is that there is no way to wire two 4-ohm speakers on one side to produce a total 4-ohm load for the amp when bridged. Wiring in series produces an 8-ohm load and wiring in parallel produces a 2-ohm load but the amp isn't 2-ohm stable when bridged. You'd be better off getting 2-ohm speakers and use the 90W x 4 setup (180W per side - the same total output as when bridged).
so running both on 1 channel would gain me more power
The amount of power is unknown according to your specs. You would be looking for ???W x 1 @ 2-ohms or ???W x 2 @ 4-ohms.
