replaced monsoon sails in TA, no sound?
i got some duel voice coil subs to replace the factory i was just told to connect the 2 channels to the 2 voice coils of the sub. i did this seperatly. i kept the factory plug and just spliced off the wires so i know i have positive and ground on right. i used the ED eu700s. i used this install guide https://ls1tech.com/forums/wiring-stereo-electronics/639901-install-guide-w-pics-upgrading-factory-monsoon-subs-6-5-ones-ed-eu700s.html i have a hole drilled for the port and a spacer made. mine isnt sealed yet, but im sure that the speaker just isnt even moving. even when i have the sub out of the sail pannel, i know that its not getting grounded out.
why wouldn't your sub be grounded out? It's connected, right?
Are you sure you did your sub wiring correctly?
http://www.rockfordfosgate.com/rftec...1&woofer_imp=3
Follow that to wire your subs correctly. I would get an amp to power those if I were you. That's my .02
no i got 4 wires a side from the factory. im just trying to replace the factory subs. the write up says to just connect the 4 wires to the 4 sub terminals. they are the same ohms as the factory. but yea they are connected.
Originally Posted by dragonrage
Nah, damage wouldn't occur unless he cranked it hard. I assume he would tell us if they worked for a minute and then stopped working.
Ungrounded Moderator
Originally Posted by onoiocoko
umm im pretty sure i got the 4+4. i taped into the wires after the harness so there is 2 red and 2 black. should i tap straight into the wires b4 it?
well i did get one working on the side thats installed. the other side i just plugged in and it worked also. but once i drove around it stopped working. im thinkin that something keeps getting smashed in the install.
