ne one know how to disable sensor for headlights
Its really easy to just put that resistor in it and tuck it back under your dash. Dont bother trying to take out the radio unless you are wanting to disable the amber lights also.
Michael
Michael
If you really want to turn them off, here is what I posted some time ago on the other board...
I haven't tried this (I like having the DRLs) but according to the wiring diagrams you should be able to simply bypass the DRL module internal relays by connecting the flasher controlled power wires directly to the lamp output wires at the DRL module. Pull the light blue with white wire and the light blue wire out of connector C1 (the larger black connector) on the DRL module and connect the two wires together. Do the same with the dark blue with white wire and the dark blue wire from the same connector.
This will make the front lights only work as normal parking lights and turn signals (no more DRL). It should not affect other functions such as automatic headlights in any way but you should check everything just in case. Who knows what convoluted logic GM may have built into the DRL module...
