HELP: stereo reception ticking??
Does anyone have a clue about what I can do to reduce the noise?
I've heard some type of filter for my amp but wasnt sure?
Edit: Actually, it might help more to know if you've changed anything ignition related any time recently to help pinpoint something.
Does it make sense that I need a filter inline somewhere for the amp... I do know that the amp wires run along the passenger side of the car where I believe the radio antenna lines are???
I just did a quick search on google in an attempt to help out some more. Here's what it revealed:
- Make sure you are using resistor type spark plugs and resistor type plug wires.
- Determine where the noise is coming from. If the noise is a popping sound that occurs 2 or 3 times a second, you probably have a loose or bad plug wire. First, make sure that all plug wires are seated properly. If this doesn't do the trick, you may have a bad plug wire. Usually this occurs due to a pinhole in the insulation of the wire. Whenever the plug wire is energized, an arc jumps through the pinhole to the chassis of the vehicle. Replace with silicone resistor plug wires.
- If the noise is a buzzing sound, the problem is usually associated with the points, distributor, or coil. Try replacing the condenser on both the coil and points. Make sure all plug wires are seated properly in the distributor cap. Additionally, you might try adding a 2200 uF cap from the positive terminal on the coil to chassis ground.
- Don't use the fuse block in the vehicle to derive power for the source unit. Run the Constant Hot B+ (memory) wire directly to the battery's positive terminal.
- If you still have noise, it could be occurring because of induction. Try pulling the source unit out of the dash and check for noise. If the noise is eliminated, try rerouting any wiring harnesses that are close to the deck. If this is not possible, try using self adhesive metal shielding. This might just do the trick.
