FP and water temp gauges not working
Old 12-27-2007 | 09:38 PM
enos44's Avatar
Default FP and water temp gauges not working
I just finished hooking up my two electric fuel pressure and water temp gauges and they are not working right. When i turn on the key, they go to zero and then the fuel pressure pegs at 100 while the water temp goes up to about 200. I have checked the ground and its fine but i did take the power wires for both gauges and put them together then hooked it to the power source. any ideas?
Old 12-28-2007 | 10:48 AM
LawmanSS's Avatar
Let's try this in the electronics section...
Old 12-28-2007 | 11:10 AM
bryan04h's Avatar
where did you put the senders? did you drill and tap the water pump or pass head? where did you put the fuel pressure sender?
Old 12-28-2007 | 12:25 PM
enos44's Avatar
i put the water temp sender in the passenger head and put the fuel pressure sender on the end of the fuel rail
Old 12-28-2007 | 03:54 PM
Mike454SS's Avatar
If they're 1 wire senders they need a GOOD connection to ground...the water temp in the head should be a good ground...FP in the rail might not though.
Old 12-28-2007 | 07:44 PM
enos44's Avatar
there is three wires going to the FP gauge and two wires going to the water temp
Old 12-29-2007 | 03:18 PM
enos44's Avatar
anything?
Old 12-31-2007 | 03:36 PM
enos44's Avatar
please i spent like another 3 hours today to no avail, this is killing me i have no idea what could be wrong.
Old 01-01-2008 | 05:05 AM
bryan04h's Avatar
well for your water temp(if it's electrical), you should have 3 wires: 1-to sender; 2-to ignition switch, 3-to engine ground
for fuel pressure(electrical), you should have 3 wires: 1-gauge ground to sender ground(also wired to engine ground); 2-to sender; 3-to ignition switch
Old 01-01-2008 | 02:13 PM
enos44's Avatar
well on my fuel pressure there is six wires, one ground one 12 volt another 12 volt for gauge light and three wires going to the sender, the water temp is the same except there is only two wires going to the sender
