Which shift kit?
Old 06-11-2013, 09:18 AM
black_beauty's Avatar
Default Which shift kit?
I have a 2000 t.a. that I'm ordering parts for to do a basic engine rebuild on and while the engine is out I'm gonna put a 3200 stall in. I was wondering how beneficial a shift kit would be to install while I have it tore apart and which one is a good kit for the money.
Old 06-11-2013, 09:45 AM
LS-ONE_DAY's Avatar
If it's torn apart you might as well, but it's really up to you. A tune can do a lot towards shift improvement also, but a shift kit can't hurt. Transgo HD-2 is the go to option.
Old 06-11-2013, 10:02 AM
I've got tune through hp tuners already. But where is a good place to get one of those at? And also since I'm at 135,000 on the clock would it be smart to go with a rebuild kit while its down?
Old 06-11-2013, 10:49 AM
LS-ONE_DAY's Avatar
Yeah I'd say so, it'd be better to than not. WS6Store should have them if their site is back up, they were having some difficulties with it the other day
Old 06-11-2013, 11:13 AM
thunderstruck507's Avatar
Transgo kit mentioned above along with this:
http://www.sonnax.com/system/instruc...7754-41-IN.pdf
Old 06-11-2013, 01:28 PM
Moderator
mrvedit's Avatar
I believe the Transgo HD2 kit is $80 on Summit.
Note that it includes optional internal parts (high RPM springs) to use if the trans is being rebuilt and you plan on shifts above 5500 rpm.
The Sonnax HD 2-3 shift valve recommended is by thunderstruck507 is HIGHLY recommended as it reduces load on your sprag and lets you drag in [D3].
Note that the shift kit requires removing the valve body and replacing springs in it. If that is more than you are comfortable with, just install the Sonnax 4060E-LB1 boost valve ($25) which only requires dropping the pan and using a pair of snap ring pliers.
Some of the trans builders here don't recommend installing a shift kit into a high mileage trans like yours. I think it comes from problems where they install a shift kit for a customer, the trans blows up (would have anyway) and the customer then blames the builder. Personally I would install the shift kit, but also plan on buying a new separator plate (Transgo Universal for $25), Torlon ***** ($10), new accumulator pistons ($10) and a reseal kit ($30) for those pistons, the servo, etc.
You might also consider the Sonnax Performance Pack (shift kit) which includes nice pinless accumulator pistons, Torlon *****, the Servo release check valve and other goodies. It is about $125:
http://hptransparts.com/sonnax-performance-pack.html
Hope that helps you decide which way to go.
Old 06-11-2013, 06:25 PM
If I go with that Sonnax Performance Pack, would that be all I need as in a shift kit?Sorry I'm not very good with the internals of transmissions let alone automatics. Also what would be a good rebuild kit to install while I'm at it?
Old 06-11-2013, 10:56 PM
Moderator
mrvedit's Avatar
Here are some recent threads on rebuild kits in which I participated:
https://ls1tech.com/forums/automatic...-kit-help.html
https://ls1tech.com/forums/automatic...-problems.html
https://ls1tech.com/forums/automatic...-rite-kit.html
https://ls1tech.com/forums/automatic...ild-4l60e.html Post #5
With a 2000 trans you will want a new sun shell and likely a new reverse drum; do pick a kit with those, or add them in.
Quick Reply: Which shift kit?
