Stans 1968 camaro LS swap and other upgrades!
Old 05-19-2011, 07:04 PM
  #361
bmf5150's Avatar
making a video now of the car,its weird in order to start i have to hit the gas pedal some to get her to start?wont start just turning the key..anyway check out the video.
http://youtu.be/VAODEsBTYxY?hd=1
Old 05-19-2011, 07:38 PM
  #362
tsnow678's Avatar
Great video! Car sounds great. Great job!!!
I am assuming you havent had it tuned yet? Sounds like you are lean on idle. Sometimes with a bigger cam they have to fatten it up just a bit to keep em from surging. This may also help with the start up.
Is that you on the video playing the guitar?
Old 05-19-2011, 07:47 PM
  #363
gMAG's Avatar
Stan, I had the same issue and did some reading here on LS1Tech.
This lead me to a drilled hole I found in the throttle plate, courtesy of the prev owner. After placing a small screw in the hole to seal it, the car starts right up with no more hesitation....just a thought.
Old 05-19-2011, 07:52 PM
  #364
bmf5150's Avatar
Yes tsnow me on the guitar,just screwing around!it's running open header with a 18 inch pipe at the end so the o2 sensors wouldn't be to close to the air outside!I gave street and performance all my cam info as well as injector size!who knows if they tuned correct,they forgot to turn vats off so I'm not to sure!
Old 05-19-2011, 07:56 PM
  #365
bmf5150's Avatar
Gmag thanks for the advice,i will check!u never know!!!
Old 05-20-2011, 01:18 AM
  #366
bmf5150's Avatar
I will prob have to take it some where and get it tuned!
Old 05-20-2011, 06:27 AM
  #367
c6matt's Avatar
did you do a crank position learn? if not get that done as well
Old 05-20-2011, 06:44 AM
  #368
bmf5150's Avatar
No I did not,to be honest never heard of it !! I will have to search for it on here!!thanks for the advice!!!
Old 05-20-2011, 07:19 PM
  #369
futureuser's Avatar
Great job and congrats! Mine runs okay without the crank learn, but I am planning on having it done when I get the tune. I think it helps the computer detect misfires.
Old 05-20-2011, 11:08 PM
  #370
BBC632Camaro's Avatar
Car sounds great man and i love the setup... Looks and sounds great!! I thought the same thing about the throttle plate before i read the other gentlemans post about it. Im sure you'll get all the bugs worked out soon. Good luck and great job!
Old 05-20-2011, 11:48 PM
  #371
68maroSam's Avatar
Very nice looking work. Thanks for sharing it and showing your steps.
Old 05-22-2011, 05:03 PM
  #372
bmf5150's Avatar
got my new foose legend rims on!!had to change all my wheel studs,all too short.nothing comes easy does it??
Old 05-22-2011, 05:08 PM
  #373
bmf5150's Avatar
still having problems with idle of the car,i can go to start the car and it idles fine,but if i put in gear it wants to die easy.the second time i have to start the car it doesnt want to start have to use gas pedal to get it started and it still wants to die.i really wonder if street and performance put the correct tune in for my cam and for my 36lbs injectors..i also need to look into the crank position learn,havent found much good info on that!!!i been checking for code,the only thing i get is a po650 code which is a malfunction indicator lamp (mil) what ever that is..any idea guys?
Old 05-22-2011, 06:27 PM
  #374
tsnow678's Avatar
Your car looks great! The only time I have heard of the term MIL it had something to do with the oxygen sensors. I am not smart at all on the electronics end of these engines yet. Have you browsed the diagnostics section on this forum?
Old 05-23-2011, 07:16 AM
  #375
c6matt's Avatar
did you install a MIL Light? did you use a LED for the mil? the PCM needs to see a resistance across the mil circuit to detect a good/blown bulb. If its missing, or an LED, it will set the code, it needs to "see" an incandecent bulb's resistance.
Old 05-23-2011, 08:47 AM
  #376
tsnow678's Avatar
I am glad someone that knows these things answered cause I sure as heck dont. Thanks Matt! I was going to use an LED but after that response I may use one of the existing bulbs from the original idiot lights.
Old 05-23-2011, 09:45 AM
  #377
bmf5150's Avatar
Hey matt,thanks for your help!I used a 12v light from radioshack,I will have to check if it is a a led or not!I dont think it is!!
Old 05-23-2011, 12:41 PM
  #378
c6matt's Avatar
I picked up one of those as well, still need to install it at some point..
Old 05-23-2011, 06:57 PM
  #379
kevmac's Avatar
bmf, great looking ride. what size are the new foose shoes? Also is this the same stance in the front you had befor the swap?
thanx
Old 05-23-2011, 08:42 PM
  #380
bmf5150's Avatar
the front end is higher due to the engine being lighter,i will need to lower it some.i will look up rim info for u,they are 18s..
Quick Reply: Stans 1968 camaro LS swap and other upgrades!
