H/C dyno results.
Old 10-23-2004, 06:56 PM
tonyt123blue's Avatar
Default H/C dyno results.
Wentto the dyno today.my mods 5.3 heads hand ported 2.02 1.57
224 .563 114lsa cam
slp lt corsa catback
ls1 edit
this is on a 2001 ws6
I put down 407 hp max at 6300 rpm and 390 ftlbs tq at 4850rpms
i had to adjust the A/f a little as I was running 14.1.after that I still put down 403 hp with a 13.4 A/F.
I dont know if this is low high or average but I am pleased.I still have work to do on my VE tables and I am going to try some more timing.
the dyno wa a super flow I belive the corrected dynojet 3 were around 426 hp
Old 10-23-2004, 09:59 PM
gtodoug's Avatar
good numbers!!
Old 10-27-2004, 05:25 PM
Scalpel's Avatar
This isn't a Dynojet, BTW. I believe his correction factor for the DynoJet brought him to near 420 RWHP I believe.
I think they are very respectable numbers based on the setup.
Old 10-27-2004, 05:43 PM
NumberOneSled's Avatar
Nice numbers!
Old 10-27-2004, 07:21 PM
beardWS6's Avatar
Nice numbers!
Old 10-27-2004, 07:29 PM
HouseWS6's Avatar
Nice #'s..
Old 10-27-2004, 11:13 PM
itchygomey98's Avatar
224 .563 114lsa cam
ls1 edit
Who did the port job?
Old 10-28-2004, 11:26 AM
2MCHPWR's Avatar
what was the torque after you richened it up?
Old 10-28-2004, 09:58 PM
close to the same I dont have the chart right in front of me.not a much canged just the a/f ratio.
Old 10-29-2004, 02:15 AM
2000 Tran Zam's Avatar
i woudl try getting the a/f down to a max of 12.9, cause 13's is still high. i made 425 rwhp and 408 rwtq with 5.7's with the 112 lsa tr 224 cam with a/f of 12.3. play around with some numbers. its better to be rich then lean too.
Old 10-29-2004, 07:25 AM
are those dyno jet #?I am on a 114 lsa so I think mine may be a little lower than a 112 can produce.I am still working on my VE table as well.
Old 10-29-2004, 12:24 PM
ya, my numbers were on a dyno jet, not mustang.
my a/f ratio should have been closer to 12.8-12.9, but i guess it is safer to keep it where i was at due to the crappy gas and heat.
Old 11-01-2004, 02:29 PM
02WSsicks's Avatar
Got my numbers in sig @ about 12.8 AF, close set-up, Good #'s man
Old 11-01-2004, 02:33 PM
02WSsicks's Avatar
Guess I should make sure my sig is updated first
anyway 432RWHP/410 RWTQ
Old 11-01-2004, 05:27 PM
dynojet#?
Old 11-01-2004, 09:57 PM
SapphireHawk's Avatar
Those are nice numbers and I am considering this setup. What drivetrain do you have?
Old 11-02-2004, 05:55 AM
m6 stock rear.will be getting a ta girdle and specIII before the sticky tires go on.
