LQ9 6.0L PT88 w/ Truck Manifolds in an FBody Build w/ Pics
Old 03-04-2009, 11:15 AM
Restricted User
98Z28CobraKiller's Avatar
*****Please note that I am copying and pasting the main posts on here from a local site that I am on more frequently. I started that thread Over a week ago so this first page is in a sort of time laps mode ******
I have officially thrown in the towel on the nitrous. With 4cyls running 8's and 9's on the street, I figured that there must be something to this new fangled turbo stuff. I decided to dive in to these new and unchartered waters (for me atleast). So without further delay, here come the pictures.
Star of the show will be this PT88.
Costarring will be this massive Air to Air intercooler with a 24X12X6 core. (Thanks BMR Tech)
I will be going backwards a little in terms of motor and cubes. I will, for the time being, be running a pretty much bone stock LQ9 (Cast Iron LS1 6.0L) long block. I picked one used and just threw it in. This was done for 2 reasons.
1) I don't know **** about tuning a Turbo so if I **** up and blow something up, it's not the end of the world.
2) It was cheap and will help to greatly reduce the down time on the car.
Once I get the low boost tune (wastegate spring) ironed out, I'll throw some rods and pistons in there and turn it up. No more forged cranks for me for a while. Pretty much everytime that I have blown my motor, I have managed to ruin my forged crank. There are lots of guys with over 1000hp on the stocker so I will be giving it a chance.
Pictures of getting started.
we cut out the radiator support in order to make some space for the turbo. The bar running across the middle is just being used as a spreader in case the gap wanted to close in a little until he welded in the relocated support.
Then he welded some caps that come out a little forward for the new support. Again, the rusty bar is just a wedge.
Here it is with the support in place and the radiator sitting in the hole. Between the radiator relocation and the use of pusher fans on the front, you get an extra 5 inches or more of clearance.
Due to all of the additional weight from the turbo, intercooler, piping and the iron block, I am trying to remove some weight. I cut the horns of the front for the bumper supports, the extra metal behind the fenders that we aren't sure what it does, and am in the process of removing the A/C.
I got my flow matched 80# high impedence injectors today from FIC Injectors. They came with a flow sheet (matched) and 2 of them flow about 4 CC's more marked for the notorious #7 & #8 cylinders.
Oh, and I also got my truck manifolds today. Flanges are running behind.
I also sent out the FiberTuned intake to have the divider plate removed which was causing most of the flow restrictions. They are also going to brace it up a little for the boost as I heard from another tester that it was flexing a bit at about 15 psi (which I wont see until I get some rods, pistons, and my heads on it). If you're curious as to what I am talking about. The answers are here https://ls1tech.com/forums/generatio...-pictures.html
Bolted on the truck manifolds and bent the power steering and brake lines out of the way on the driver's side. Mocked up the intercooler so I can get some tabs welded on it at another friend's house with a TIG welder. Looks like it will be easy to mount without adding too much bracketry and **** to the nose.
Made some progress yesterday. Put the fenders back on and got the hood aligned good with the bracket that holds the latch. In an effort to keep the fabrication down to a minimum, we decided to mount the intercooler (top bracket) to that bracket so we had to make sure that one was in the correct spot after reassembly. Bolted the intercooler on top, measured and welded some plates to the bottom radiator support to reach the bottom of the intercooler. It is very sturdy.
This morning I went over there and ground down the welds, sanded, painted the bare metal and cut the front of the bumper cover for better airflow.
Just got this stuff last night and now we can get started on the hot side.
Going with the Tial 50mm BOV (Q) and Tial 44mm Wastegate.
Old 03-04-2009, 12:46 PM
Louis's Avatar
How much boost? or how Low of boost? I couldnt get the 44 to control it. I went to a TurboSmart Pro50...
Nice build!! Its gonna scream!
Old 03-04-2009, 01:16 PM
Restricted User
I'm starting out on the 8psi spring. I figure that the stock longblock should be able to survive that for a while. I'll get the tune dialed in and make some clean passes. Then throw the forged rods and pistons in there. Throw my AFR 225's on and turn it up till she pushes water.
When you say you couldn't control it, what do you mean exactly? Too much boost? I did a lot of reading and this one seemed to be the right sizer but then again, I admit, I don't really know much about turbo's YET. I guess that it wouldn't feel right if I didn't have to buy at least one component twice.
Old 03-04-2009, 01:28 PM
crf538's Avatar
i put a 3.5 spring in mine just to shake it down because it was a stock longblock, ended up making about 4.5 pounds and made tuning much less sensitive to screwups( it was the first time i had ever tuned as well). After i got that tune good i got an eboost 2 and turned it up with that.
ive got a 38mm turbosmart and it controls boost just fine on my setup.
Old 03-04-2009, 01:29 PM
LS1Tech Sponsor
hellbents10's Avatar
Build looks great! You will have a ton of fun with it.
Shoot those Lq9's are good for it, at least 900hp on good fuel before the rods start to bend. Good enough for a years worth of 140+mph traps at 3950lbs........in Dave's case.
Old 03-04-2009, 01:49 PM
Restricted User
I'm hoping to stay under 3700 lbs. I weighed it in at 3665 with me in it with the aluminum block. I'm hoping that removing the AC and some other little things will offset the iron block weight and the turbo stuff.
Who's Dave?
What size turbo?
Old 03-04-2009, 02:25 PM
darooke's Avatar
I have the same build going but mine is a forged 370 lq9. I just purchased a pt88 with a 1.00 A/R housing. I will be watching your build. Great start.
Old 03-04-2009, 03:02 PM
Restricted User
Can someone tell me what the mating flange to the oil drain is called and what size size should I be running?
I'm assuming the other end of the flange comes with either a male or female pipe thread or AN?
All that the turbo has written on it is PT88 (etched) on the charge pipe housing. It has a T4 flange and I was told that the exhaust housing is a 96 AR.
Also, for the downpipe, I measured the inside of the exhaust housing outlet at 4" and the outside at 4 1/2" with a deep groove that appears to be for a vband clamp.
What size vband do I need to order and weld on the 4" down pipe? I mean, is it based on the ID or OD?
Old 03-04-2009, 03:19 PM
Louis's Avatar
The oil drain flange and turbine outlet flange/vband are Precision parts. I think I spend 150~ on mine.
I wanted to control Boost down to 7#s. Engine combos will change that for sure, but I could only control it to ~ 9#s with NO spring. I wacked off the Tial 44 and welded on a ProGate 50 just to be safe.
you might be fine? but since you drag race ( As do I) I needed the control, or ability to control it down to as low as possible for varying track conditions, bad prep, etc.
Again, its easy to change it now. Its much harder to reconfigure it all when the setup is done and running.
Old 03-04-2009, 03:56 PM
Restricted User
So you can only buy those 2 flanges from Precision, direct? Sounds like *** rape at $150 for 2 flanges.
As for the Wastegate, I'm going to have to run it as is and hope that my lower cubes and suspension can hold the power at as low a boost as this thing will allow me to go. Thanks for the heads up though.
Old 03-04-2009, 04:09 PM
Mean Green z28's Avatar
looking good so far! someday hopefully I can get the $'s to start on mine
Old 03-04-2009, 10:07 PM
dman's Avatar
LOS, **** that.. bring the turbo by and i'll get you setup with what you need. Was that you calling the other day about the MP-4303 pump? i was busy and didn't put the name together while we were on the phone.
Darin
Old 03-04-2009, 10:11 PM
Louis's Avatar
Yep, pretty much.
Old 03-05-2009, 12:43 AM
Restricted User
Darin
That was me. Killer price by the way! I am not going to order it yet as I wont need it until I start turning the boost up. I've already got a nice list going of the **** that I need for the cold side. Would have gotten the hot side stuff from you as well if I knew that that is the kind of stuff that you guys do.
Thanks!
We got the hot side all tacked together. What a pain in the *** that was. Measure cut measure cut measure cut trying to get all the mandrel bends to line up without being able to bend any pipe.
Here is the center section with the T4 flange. Basically it's a u-bend 2 1/2" cut in half, filleted and turned back on itself.
Here it is almost all tacked up missing the driver's side elbow.
All tacked and ready to be welded up on the bench.
Most of the other front mount single turbos that I have seen have the exhaust side aimed at the passenger side. I found that the passenger side manifold came down so far that I wouldn't be able to take advantage of the turbo k-member and would have had to route the down pipe between the motor mount tower and the block. By flipping it the other way, I can easily fit a 3 1/2" down pipe and might be able to squeeze a 4" pipe thru there. Any thoughts?
Old 03-05-2009, 09:43 AM
dman's Avatar
make sure you leave room to plumb in the wastegate... right at the union would be optimal
Old 03-05-2009, 10:27 AM
TripleWhite96's Avatar
Nice man, welcome to the turbo fbodies..your car will be like mines older brother. :p
Old 03-05-2009, 11:24 AM
smokinHawk's Avatar
i bought my 4" vband connection through an online semi-truck exhaust place was pretty cheap, also got my vband clamps from there.
what kmember are you using? i squeezed a 4" DP with a regular bmr kmember through the passenger side, with the turbo kmember you should be able to put a 5" through it (maybe not on the passenger side though)
Old 03-05-2009, 12:17 PM
Restricted User
I got lots of space up front. I'm not sure that the radiator relocation was even neccesary. Now I have room for the 91.5 down the road
I hope I don't run into any problems taking the downpipe back on the drivers side between the frame and the motor mount tower. I don't want it running on the inside by the block as that would make the turbo kmember useless. I stuck a 3.5 inch pipe in there and it had plenty of space so we'll see.
Old 03-05-2009, 01:12 PM
dman's Avatar
that 3.5" dp should be enough for some 8 second passes.. I also have a LQ9 but i'm putting twin T70's on it.. i think you'll be suprised at how fast stock parts can go when you have turbo powa
Old 03-05-2009, 02:38 PM
Restricted User
It's funny because I was looking at the t4 flange thinking "how the hell can you make any power through this little hole?". I am going from true dual 3" exhaust with 2" primary headers to this stuff. It's an entirely different strategy that is forcing me to have lots of faith in what I read.
Quick Reply: LQ9 6.0L PT88 w/ Truck Manifolds in an FBody Build w/ Pics
