Ring gap for turbo motor
Old 01-07-2013, 07:45 PM
6PntHo's Avatar
Default Ring gap for turbo motor
Going to have a 347. Stock crank, Callies rods , diamond pistons.
It's going to be N/A for a little bit, but it will have a rear mount build. Ill be running no more than 12lbs. With a 67mm. What should I gap the rings too?
Old 01-07-2013, 08:00 PM
LS1TOYOTA's Avatar
Pick one
https://ls1tech.com/forums/forced-in...ted-5-3-a.html
https://ls1tech.com/forums/forced-in...ring-gaps.html
https://ls1tech.com/forums/forced-in...-opinions.html
https://ls1tech.com/forums/forced-in...-ring-gap.html
https://ls1tech.com/forums/forced-in...sive-blow.html
Old 02-08-2013, 06:51 AM
6PntHo's Avatar
Bump... Gapped the top to .022 and the second to .014. Will that work?
Old 02-08-2013, 09:25 AM
HRHohio's Avatar
Nice! This post alone deserves to be a sticky! LOL With as many people who search and start new posts.
Old 02-08-2013, 09:52 AM
BMF_Racing's Avatar
its on the tight side in my opinion. I'd go .026/.028 and have room to grow for more power down the road. I have no blow by issues at .030/.030.
good luck
Old 02-08-2013, 10:10 AM
ibex37's Avatar
good info
Old 02-08-2013, 06:38 PM
6PntHo's Avatar
good luck
I went by what the paper said with the total seal rings?
3.905•.0055 for the top
3.905•.0035 for the second.
Old 02-08-2013, 07:55 PM
BMF_Racing's Avatar
Wiseco's same base guidelines said .024 for my turbo motor. After calling them and explaining what my build was they said 0.030" and .0055 piston to wall clearance (.0035 on the paper with the pistons).
It will work, just a lil tight.
Quick Reply: Ring gap for turbo motor
