Walbro 400 lph Fuel Pump
Old 09-22-2011, 01:25 PM
rao
rao's Avatar
Default Walbro 400 lph Fuel Pump
I searched and did not see any of mention of this here:
http://www.dynosty.com/2011/08/walbro-400-fuel-pump/
http://www.racetronix.biz/itemdesc.a...000262&eq=&Tp=
Looks to be promising.
Old 09-23-2011, 04:06 AM
LS1TECH Sponsor
Racetronix's Avatar
Coming very soon ...
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 09-23-2011, 09:32 AM
bravolistick's Avatar
So is this supposed to be better than the new stealth 340.... looks like it
Old 09-23-2011, 12:37 PM
LS1TECH Sponsor
Racetronix's Avatar
They should flow a bit more with less heating of the fuel. They will not fit many apps b/c of the case profile / size. We are working on some new kits for race season 2012.
__________________
>WEB SITE<
Old 09-23-2011, 07:22 PM
This wont clear a gto bucket? I've dremeled the top portion of my stocker so I have lots of room up top. Based on the pictures it looks to be biggest on the bottom. Is the upper portion the same diameter as the other walbos?
Old 09-24-2011, 10:46 PM
408ws6ta's Avatar
Will this fit a 2000 T/A? Anyone?
Old 09-25-2011, 12:57 AM
LS1TECH Sponsor
Racetronix's Avatar
Not in its factory format.
__________________
>WEB SITE<
Old 09-25-2011, 01:28 AM
9 Second Truck Club
stock48's Avatar
That looks like a bad *** pump. I need one in a inline do they have one?
Old 09-25-2011, 01:34 AM
LS1TECH Sponsor
Racetronix's Avatar
No but there is this option:
http://www.racetronix.biz/itemdesc.a...WSP330&eq=&Tp=
__________________
>WEB SITE<
Old 10-05-2011, 10:26 PM
Beejis60's Avatar
Just saw this....
And I literally JUST bought a bosch inline to couple with my 255lph hp.
Old 10-09-2011, 03:03 AM
bettonracing's Avatar
Do You have a drawing for the pump?
Is this pump E85 compatible? If so, how many hrs is it rated for on E85?
Thanks,
Kurt
Old 10-10-2011, 03:02 PM
ls1408cp's Avatar
bump.... update?
Old 10-13-2011, 06:16 PM
Rebump...
Old 10-17-2011, 11:19 AM
NemeSS's Avatar
*crickets*
Old 10-17-2011, 11:35 AM
LS1TECH Sponsor
Racetronix's Avatar
It is not certified for use with E85. None of the new HP pumps are truly E85 compatible.
It can not be used with the factory bucket / jet pump system.
It produces too much fuel volume to be used with the factory regulator and return system.
In its out-of-the-box format it is only good for custom applications.
We are developing some new applications for release next spring / summer.
__________________
>WEB SITE<
Old 10-17-2011, 01:12 PM
AutomagicLS1's Avatar
Why is the 400 not certified/compatable to be used with E85? Whats the compatible/cert differences between the 255's on E85 and the 400 mia?
Old 10-17-2011, 01:33 PM
LS1TECH Sponsor
Racetronix's Avatar
255's are not.
Pumps that are certified are made from materials which are resistant to the corrosive properties of E85.
__________________
>WEB SITE<
Old 10-17-2011, 02:17 PM
ls1408cp's Avatar
well i was wanting to cut up my 99 bucket and install one. I am going to run a regulator with stock lines and evap. I was hoping this would be better the running two seperate 255s in e85 also
Old 01-27-2012, 10:36 PM
Ws6power1's Avatar
What about a 98 fbody since there isnt a bucket around the fuel pump?
Old 01-27-2012, 10:37 PM
Ws6power1's Avatar
will it fit a 98 that is?
Quick Reply: Walbro 400 lph Fuel Pump
