Ac removal?
Old 03-10-2010, 09:19 PM
MYSTIC-1SC's Avatar
Default Ac removal?
I was just wanting to know what all is involved in removing the ac system and all its accessories other than the obvious things. I just want to know what to consider and what ill need to do to eliminate the ac and all its components.
Old 03-10-2010, 09:28 PM
chrs1313's Avatar
dryer, compressor, and condensor... that about covers it...pretty easy... good luck
Old 03-10-2010, 09:38 PM
MYSTIC-1SC's Avatar
k i figured it was pretty simple but since i've never removed the system from an f-body before i wanted to make sure there was nothing particular i should know about.
What about belts any body know what size ill have to switch too
Old 03-10-2010, 09:57 PM
tromanf3's Avatar
I was wondering about the belts too but i was under the hood the other day and it looks like the AC runs on it's own separate belt, so I'm thinking you could just remove that and be fine? Someone correct me if I'm wrong. I'm looking to do the same thing down the road.
Old 03-10-2010, 10:05 PM
MYSTIC-1SC's Avatar
yea i believe it does but ill have to run out to the shop and check tomorrow.
Old 03-10-2010, 10:33 PM
conan's Avatar
Here's a thread I didn't feel like retyping that my help...
https://ls1tech.com/forums/generatio...-c-system.html
Old 03-10-2010, 11:26 PM
99T/AVert's Avatar
I want to remove my a/c but keep the heat. Since I have a vert, the a/c does not do all that but the heat will come in handy.
Old 03-11-2010, 06:52 AM
chrs1313's Avatar
same setup I have...ac has been gone for 3 years now...but heat will probably never leave...
Old 03-11-2010, 07:12 AM
99T/AVert's Avatar
lol yeah there is not much use for a/c with a vert. Did you pull anything out from under your dash or was it just the stuff under the hood? I was even thinking of moving my a/c controls to the glove box or somewhere else and maybe even making the controls more simper with just am on/off switch, cuz if I need heat then it is always on full blast, no need for all the controls except for an on/off button lol.
Old 03-11-2010, 08:58 AM
conan's Avatar
I still have my heat too. The A/C removal was all under the hood. I have never seen behind my glove box.
Old 03-11-2010, 09:19 AM
bww3588's Avatar
i cut and removed my evaporator box and made a block off plate. still have heat, but under the hood is much cleaner.
Old 03-11-2010, 09:20 AM
99T/AVert's Avatar
Any pics
Old 03-11-2010, 09:32 AM
bww3588's Avatar
negative. i didnt get a chance to snap any pictures.
basically, you just cut everything that protrudes into the engine bay flush with the firewall. then make a plate to cover the hole. just make sure on your plate you cut holes for the heater hoses.
bww3588's Avatar
actually, i have the engine out of the car now, ill snap some pictures when i get home if i remember.
Old 03-11-2010, 09:34 AM
99T/AVert's Avatar
Is that the big hole on the firewall on the pass side?
Old 03-11-2010, 11:18 AM
bww3588's Avatar
yep. ill get some pictures if i remember.
if not, if you search "ac delete" you will find a good thread with awesome pictures.
Old 03-11-2010, 11:21 AM
99T/AVert's Avatar
Thank you
I will also look up the ac delete threads.
Old 03-11-2010, 11:42 AM
conan's Avatar
Here's a thread I couldn't find yesterday. Check out merv's post.
https://ls1tech.com/forums/generatio...leting-ac.html
Here's a pic of what I left in the car. Look in the top left corner of the pic, see the 2 red plugs. That is what merv took out and made the new plate to cover the hole.
http://mycarpics.shutterfly.com/204
Old 03-11-2010, 12:15 PM
99T/AVert's Avatar
Thanks for the pic and link! Did he make that plate cover or does one of the sponsors make them?
Old 03-11-2010, 03:29 PM
conan's Avatar
I think he made the plate him self. You could take the OEM plate and trace it on a sheet of metal and cut it out with a angle grinder.
Quick Reply: Ac removal?
