Those with Edelbrock Victor Jr. step inside...
I am throwing an Edelbrock Victor Jr. intake manifold on my new H/C setup. I am debating on using a NW 90mm TB or a Holley 105mm TB and converting to the Ford IAC & TPS. Both using a Wilson manifolds 100 degree elbow. Any thoughts would be appreciated.
RyanK & kp are your best sources for that setup.
Here's some threads I've gathered on the subject:
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<picture
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
Just so you guys know, you cant run a FORD iac motor with the stock pcm. You have to use an adapter plate made by FAST or ASSC to mount a gm IAC valve ( like the one I have for sale ).
Also, you dont have a choice with the PTE or WIlson manifolds elbows... you have to run a 4 bolt ford tb with that bolt pattern unless you weld on a new mounting flange on the tb side...
