Trick Flow's 205cc heads
Old 05-12-2009, 09:46 AM
LS1Tech Sponsor
TrickFlowTech's Avatar
Default Trick Flow's 205cc heads
Our new 205cc heads are on the market!
2 different variations are available right now.
TFS-30500001-C00 fully cnc'd head with chromoly retainers.
THESE CYLINDER HEADS FEATURE :
205CC CNC MACHINED INTAKE PORTS
80CC CNC MACHINED EXHAUST PORTS
58CC CNC MACHINED COMBUSTION CHAMBERS
2.000"/8MM STAINLESS STEEL INTAKE VALVES
1.575"/8MM STAINLESS STEEL INTAKE VALVES
1.300" DUAL VALVE SPRINGS WITH CHROMOLY STEEL RETAINERS
150 LBS @ 1.800" INSTALLED HEIGHT
438 LBS OPEN @ 1.200"
448 LBS PER INCH RATE
.600" MAXIMUM LIFT
TFS-3050T001-C00 same cylinder head with titanium retainers.
1.300" DUAL VALVE SPRINGS WITH TITANIUM RETAINERS
.600" MAXIMUM LIFT
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 05-12-2009, 10:35 AM
PREDATOR-Z's Avatar
Any flow test results?
Old 05-12-2009, 11:35 AM
LS1Tech Sponsor
Lift intake exhaust
0.100 66 52
0.200 135 109
0.300 203 165
0.400 257 209
0.500 287 222
0.600 299 237
__________________
Old 05-12-2009, 02:27 PM
DONAIMIAN's Avatar
Pricing? What can the spring pockets be opened up to?
Old 05-12-2009, 07:12 PM
triggerjerk's Avatar
I think we need an AFR 205 vs TFS 205 sponsor shootout!
Old 05-12-2009, 09:06 PM
52172's Avatar
is the price the same as the 215 I would imagine?
Old 05-12-2009, 10:20 PM
99Ls1fever's Avatar
Hope not cause they dont flow as much as the PRC heads for 1/2 the price.....?
Old 05-13-2009, 05:37 AM
rmtt's Avatar
I think he is talking about the TF 215's.
Old 05-13-2009, 08:59 AM
LS1Tech Sponsor
For the chromoly retainer heads $1995.95. Ti retainer heads are $2195.95.
The spring pockets are 1.480" and can be opened up to handle a 1.550" spring but you can not go deeper on the pockets.
__________________
Old 05-13-2009, 11:01 AM
99Ls1fever's Avatar
But for the Price I would just go a different route IMO
Old 05-13-2009, 11:44 AM
PREDATOR-Z's Avatar
Perhaps may I suggest that you make a small writeup on where and when do you recommend those heads (application, cam range, rpm, complementing mods etc..)
Why them over the 215s, why them over stock casting ?etc....
Old 05-13-2009, 12:14 PM
eamador11's Avatar
I agree, Im curious to know too.
Old 05-13-2009, 05:32 PM
larrygto's Avatar
OK my cam runs 595"-598" lift that falls below the 600" max but is quite close. Is this safe or would I need upgraded springs?
Old 05-13-2009, 05:55 PM
firefighter813x's Avatar
X2! Thanks
Old 05-13-2009, 07:07 PM
Spectre86's Avatar
velocity. There is more to a head then flow numbers.
205cc head vs a 220cc head.
Lift intake exhaust
0.100 66 52
0.200 135 109
0.300 203 165
0.400 257 209
0.500 287 222
0.600 299 237
those numbers are close to the same with the AFR 205cc heads.
Old 05-13-2009, 08:59 PM
MelScrilla's Avatar
subscribing looking forward to a write up
Old 05-14-2009, 10:36 AM
larrygto's Avatar
I think I want these!
Old 05-14-2009, 11:04 AM
99Ls1fever's Avatar
What is the differance between 205cc and 220cc so I know for the future. So, I understand better. thanks
Old 05-14-2009, 11:12 AM
blown03mustang's Avatar
+1 id like to know how theyd work out with my torquer 2 vs the maybe the 215cc
Old 05-14-2009, 11:26 AM
Spectre86's Avatar
bigger port. bigger port flows more air which = higher cfm/flow numbers
you lose velocity though. so unless you have the cubic inches or forced induction to push that much air through a bigger port, your going to give up low end power.
Quick Reply: Trick Flow's 205cc heads
