TEA Stage 1 243s
Old 11-26-2009, 08:06 AM
BaddBird's Avatar
Default TEA Stage 1 243s
Does anybody know how much milling is done on the TEA 243s to get to 61cc?
Old 11-26-2009, 09:07 AM
bigboykilroy's Avatar
I Had TEA do mine to 61cc Stage 2 thought. I dont think it was on my paperwork how much they cut, I will find out for you thought.
Old 11-26-2009, 09:11 AM
BaddBird's Avatar
Hey that would be great. I see your running a 224/230 cam did you have any PTV issues with the 230 duration and the 61cc heads.
Old 11-26-2009, 09:28 AM
outkast6991's Avatar
to get from 64cc to 61cc on a 243 should be roughly .018 milled off. they say 1cc is roughly 6 thousandths
Old 11-26-2009, 09:42 AM
BaddBird's Avatar
That would probably be correct on a stock chamber but TEA cnc's the chamber out bigger to unshroud the valves so you have to mill more to get to 61cc.
Old 11-26-2009, 11:45 AM
Im also running 1.8 rockers. Im very close but no issues, I would say im maxed out on the ptv. I'm also running the lifters not tight preload. about .65 preload.
Heads milled to 61cc that should be about .020" but I'll check with Brian.
Old 11-26-2009, 03:09 PM
printmanjackson's Avatar
will this bring the compression up to 11:1?
Old 11-26-2009, 03:29 PM
BaddBird's Avatar
If you are talking about the TEA cnc'd 243s. Yes running the mls gaskets
Old 11-26-2009, 08:05 PM
eamador11's Avatar
contact brian tooley @ TEA
Old 11-26-2009, 10:55 PM
Chris05ssTruck's Avatar
Yea, Tooley is a GREAT guy and knows his **** for sure!
Old 11-27-2009, 10:07 AM
BaddBird's Avatar
ttt^^^
Old 11-30-2009, 10:28 AM
Got in touch with Brian Tooley and he said (For the Stage 2 Heads cut to 61cc)..
"They were probably milled .020"-.025"
He also agreed that the Stage 2 heads milled to 61cc using a stock MSL Gasket should be about 11:1 compression.
But as always those numbers are a guide you would have to measure your setup with all YOUR ENGINE clearances to get YOUR engines compression.
Hope this helps.
And if I havent said it before I LOVE MY TEA HEADS !!
Quick Reply: TEA Stage 1 243s
