TSP come in!!! Help me pick a H/C combo!!!
So I finally just bought my first LS1 Fbody. It is a 99 Trans Am A4. I am still deployed to Iraq but I had my cousin(who is also a member here) pick the car up and store it for my while I am here. For awhile, I was sure that I wanted the TSP Tsunami cam with the PRC 2.5 LS6 heads, but now I just dont know I know I am going to go with the PRC heads but whether or not I get the 2.5 LS6s or the 2.5 5.3 heads, I am not completely sure. The same thing with the Cam. I have read a few of the dyno threads here and I am very very impressed with the cam, however, my car will be a daily driver. I am going to get a Yank converter but it is still a toss up between the SS3600 or 4000. Eventually, I would really like to spray a 125 shot on it so I guess the cam needs to be good for that....
All in all, I am shooting for low 11s high 10s and hoping to do it on the stock short block and preferably with over 400rwhp with the A4.
Being that I am over here and the lack of phones, It is hard for me to give TSP a call as I would like to so I am hoping that they could give me some advice on here or PM. I am planning on ordering all of this in the next few weeks so I want to see if TSP will chime in here. I have heard nothing but good things about them and I want to give them as much of my business as possible. I just wish I had heard of them before I moved out of Lubbock before this deployment.
Thank you guys in advance.
I have thought about picking up those heads but they are a little more than I want to pay. I would like to stay with one of the OEM-type PRC castings if I can.
LS1Tech Premium Sponsor
If it's a budget issue, I'd go with the PRC Stage 2.5 LS6 heads! They are going to perform better than the 5.3's, for just a little more money. The Tsunami is an awesome camshaft, but as stated above, you definitely need a good higher stall converter to run it!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes, 3600 will do nicely with the Tsunami and up to about a 150-200 shot! Those pieces will work nicely together!
__________________
Unfortunately, track times are harder to predict and have even more variables than dyno numbers!
__________________
What do you dyno and run at the track now?
__________________
Right now the car is stock with a catback. I just bought it and I have not even seen it in person yet(I am in Iraq). So I am not sure what it dynos or runs at the track.
anybody else??? I think I am going to end up going with the tsunami/2.5 LS6 combo....
How much can I have the head milled before I have to worry about PTV issues? Is higher compression even good for nitrous? I saw in one of the threads with that combo that the heads were milled to 62cc. Can I get them from TSP like that? Sorry for the questions, I just really want to make sure that I have everything right before I order from TSP
We can mill the 2.5 LS6 heads about .010-015" without piston to valve clearance issues. Give me a call and I can make sure you get everything you might need for the install too. We're only open until 12:00 central time today, and won't re-open until 9:30 central time on Monday, at which time the sale will be over!
__________________
