Anyone use a 0 overlap cam on purpose?
I would really like to know if anyone has used something along the lines of a 236/236 - 118 cam. This should still be big, have no overlap, smell better, etc, right? Probably would need some low compression pistons since PTV would be an issue....Would it make a good FI cam for a 408?
well yeah, but also less top end power but I am mainly wondering about cylinder pressures even with low compression and how much less top end with that sort of duration.
right now my cam is 236/244 on a 114 and has 12 degrees of overlap. i want to know if going to zero degrees is going to make a difference in the smell, the idle quality, the power curve effects, ptv clearance with that lsa, etc.
It would idle/smell better and you'd actually have more PTV because of the wider lsa. It's going to peak higher in the powerband, but have a very wide curve. It wouldn't necessarily be better for boost because of no exhaust bias though and it wouldn't need lower compression as cylinder pressure would go down with the later IVC point.
The cam I just bought for my LS3-headed 402 has no overlap. LS3 heads don't respond well to cams with a lot of overlap, so it's really not uncommon to see little or no overlap on LS3-headed cars. Most mild cams don't have any overlap either.
I'm thinking this would be a very good EFI cam, but I would be very worried about detonation with no overlap. But hey...that's just what I'm thinking. I need to think more about SNL's statement. But with no overlap, all the charge is staying in the cylinder.
236236, aggressive, boost, cam, camoverlap, camshaft, compression, ivc, lap, low, lowers, ls1, overlap, smell, superchargers
