Got My Custom Cam Spec's
Old 12-30-2008, 11:24 PM
Grn4fbody's Avatar
Default Got My Custom Cam Spec's
Pat G from LS1tech has been helping me get a custom ground cam for my car and this is what I got back Very Happy
Cam recommendation: (2002 F-body with stock 346 LS1 engine, 67cc stock heads, .054” gasket, LS6 intake, 78mm TB, M6, 4.11 gear, 1 3/4” long tube headers with no cats, 6600 rpm shift points, 6800 redline)
231/231 .617”/.617” 111LSA +4 advance (with 1.7 ratio rockers)
Comp LSL/LSL lobes
13018R/13018R HR111LSA +4 advance (107 installed intake centerline)
Cam Valve Events 0.006 0.050 0.200
Intake Duration - ID 281 231 154 13018R LSL lobe .617"
Exhaust Duration - ED 281 231 154 13018R LSL lobe .617"
Lobe Center Angle - LSA 111 111 111
Intake Centerline - ICL 107 107 107
Intake Valve opens - IVO 33.5 8.5 -30 BTDC (- indicates ATDC)
Intake Valve closes - IVC 67.5 42.5 4 ABDC
Exhaust Valve Opens - EVO 75.5 50.5 12 BBDC
Exhaust Valve Closes - EVC 25.5 0.5 -38 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 115 115 115
Overlap 59 9 -68 degrees
• Static/Dynamic Compression with new cam: 10.28:1, 8.02:1
• Recommended valve springs: Patriot Extreme duals with Ti retainers.
• Recommended pushrod length: 7.450”.
Now to know what size injector's I need(I was just thinking 42's...not to big and the duty cycle can be turned down), and to order my fuel pump, also find some pushrod's. I'm looking at the TR set, and also at the Comp Cam Chrome Moly's.
I'm super stoked Very Happy
Old 12-31-2008, 01:23 AM
Nitroused383's Avatar
That thing is going to run like a raped ape. I too am considering building a cam on the LSL lobes. I do know how hard they will be on springs so let me know what you think. You need to get an idle clip of that thing too, it's going to sound like a demon.
Old 12-31-2008, 01:31 AM
LS1-NAVY's Avatar
hmm i like that alot i was looking at the torquer v3 but the .643 lift is killer. i wonder what a 231/234 .617/.617 would be like?
Old 12-31-2008, 01:42 AM
Cvaught's Avatar
I am eager to see how this performs, keep us updated.
Old 12-31-2008, 05:39 AM
PREDATOR-Z's Avatar
Nice, I would be curious comparing that to my XFI/XE-R grind "El Torro"
(230/230 .612/.598 111+4 LSA) to see the effect of LSL lobes on the powerband.
Old 12-31-2008, 07:53 AM
chrs1313's Avatar
Me too would be interesting to see...to the op you better check PTVC with that cam i know my 230/230 on 111+4 was .072 on the intake...
Chris
Old 12-31-2008, 07:59 AM
Bad Blue WS6's Avatar
isnt anything over .600 lift going to be in the "flycutting" zone? Probably a dumb question, sorry, but im just learning when it comes to the H/C stuff.
Old 12-31-2008, 08:08 AM
DaveX's Avatar
Not necessarily. Duration and valve timing have more to do with piston/valve clearance.
Old 12-31-2008, 08:59 AM
teke184's Avatar
with stock heads, you probably can get away with stock injectors.
if nothing else some FMS 30# would work
Old 12-31-2008, 09:57 AM
Grn4fbody's Avatar
I plan on spraying a dry shot on her....and all the FMS injector's are the same price new.
Old 12-31-2008, 12:18 PM
Adam1982's Avatar
Nice looking cam, Pat specd me one just a little smaller 227/231 similar lift on LSL lobes 113+4. I believe TR is out of their pushrods, but they can get you the comp ones. TSP also has chromoly pushrods in that size. Good luck with it, post up some numbers and vids when its done.
Old 12-31-2008, 12:21 PM
Grn4fbody's Avatar
I checked the TSP site and I didn't see any that size. I believe I'm just gonna go with the comps
Old 12-31-2008, 12:22 PM
Peetyz's Avatar
Should be a good choice keep us updated
Old 12-31-2008, 12:37 PM
Adam1982's Avatar
They arent on the site but they have them, I bought them yesterday.
Old 12-31-2008, 01:12 PM
chrs1313's Avatar
again i would definitely check PTVC... you will most likely be around 0.06x for the intake...standard street driven clearance is 0.080 intake...dont assume it will fit
Old 12-31-2008, 04:46 PM
Grn4fbody's Avatar
It's not like it Pat G's first set up, I completely trust his info.
Old 01-01-2009, 01:17 PM
chrs1313's Avatar
so what clearance did he say you will have then...every engine is different...there is a reason why there is a save standard of 0.080 and .100...
if anything cams get made wrong more often than you think...so go through the time of either having the cam doctored or degreeing it yourself in the car...if you dont wanna check PTVC dont, peace of mind IMO though...
Old 01-01-2009, 02:05 PM
LS1 Tech Administrator
Patrick G's Avatar
Chris
Should be no P to V clearance issues if installed at 107 ICL. Your cam with it's XFI lobe on the intake is most likely closer to 232 at .050" and 283ish at .006" in duration (when measured on the cam doctor), making things a little tighter. The 231 LSL lobes are closer to 281 at .006". Also, the IVO (where you run into trouble) is 4 degrees later at .006" than a T-Rex. The T-Rex, while tight, still fits. A 4 degree later IVO gives you lots more breathing room.
I've spec'd over 100 cams in the 230 at .050" range for cam-only applications and none have reported dangerous P to V clearance. Russell should be able to run this cam with confidence.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-01-2009, 02:14 PM
Grn4fbody's Avatar
What I needed to know Pat, thanks
Old 01-01-2009, 03:13 PM
PREDATOR-Z's Avatar
Read carefully what Patrick said. His first words are "There should be no issues if cam is installed at 107 ICL". Are you going to degree the cam?
dot to dot doesn't necessarily mean it is at that. the .050 specs are generic and the grind will not be exactly at those figures. So it is always wise to degree and check PTVC. Not only will you know what is happening but also you'll benefit from the true valve events that Patrick laid out for ya.
Paying attention to detail on install of cams ensures every ounce of power we so dearely seek is taken out of it.
Quick Reply: Got My Custom Cam Spec's
