Ported TB, now high idle.
Old 02-12-2009, 06:11 AM
TireSm0ke's Avatar
Default Ported TB, now high idle.
I ported my TB today, just used a dremel and ported it pretty big, also knife edged the blade and cut the shaft, and now its idling around 900-1100 stopped at a light and around 1800-1900rpm if I put in in D or N. When I start the car, it idles normally at 500rpm, but once I start moving I get these problems. The pedal also feels like the blade is getting a little stuck off idle... Any ideas?
Old 02-12-2009, 06:35 AM
Grimes's Avatar
did you end up porting the area where the throttle blade closes? if you did, there may be too much air entering even though the blade is closed.
Old 02-12-2009, 06:45 AM
chrs1313's Avatar
yup sounds like you ported to close to the throttle blade, also i am guessing you took off too much material when you knive edged the butterfly...might wanna get a new blade...if that doesnt help, you will need a new throttle body...
Old 02-12-2009, 07:50 AM
nemss1's Avatar
your TB is over-ported around the TB blade. thats what would be causing your problem
Old 02-12-2009, 09:37 AM
LSX Mechanic
Damian's Avatar
When I was porting TB's for the masses I quit knife edging the blade because it was causing idling issues. There's no other way to fix it other than replacing the blade.
FYI, you're probably seeing 50% or less of the porting gains doing it with a dremel. There's no possible way you can properly blend, smooth, and remove the right amount of material with one. I've tried several times before and it's not possible, compared to using the correct tools. You might want to send yours off to be finished, and have the blade replaced at the same time.
Old 02-12-2009, 10:54 AM
IWGF's Avatar
Now, I'm not trying to snake your technique or anything, I do some porting myself, but could you elaborate on what tools and technique you're using? PM me if you don't want to tell everyone on the board.
Thanks!
Old 02-12-2009, 11:18 AM
CodeRed2000SS's Avatar
X2, Sounds like you have cut to much around where the blade closes up
Old 02-12-2009, 12:03 PM
TireSm0ke's Avatar
Well I marked where the blade sits before I started porting and Im pretty sure I didnt hit that area... I drove it this morning and it seems like the blade wants to stick when in the closed position. For example ill start the car the idle will be normal but as soon as I tap the throttle it feels like I have to break the blade loose, and my idle problems begin from there. Is it possible the blade is not centered correctly?
Old 02-12-2009, 12:06 PM
aothepresident's Avatar
Yea, I had the same problem, seems like it is definitely sticking, could be off-center like you said. Take it off and manually open and close it, you should be able to see pretty clearly where it's sticking
Old 02-12-2009, 12:08 PM
12secSS's Avatar
Evan,
Sounds like the throttle blade is not centered or the blade is closing too much and binding on the housing. Center the blade on the housing by loosening the blade bolts and allowing the blade to sit freely while closed. Tighten the bolts in place. Then ensure the blade is not sticking as you crack it open, you will need to adjust the idel set screw to hold the blade just a hair open, just prior to sticking. If you need help, just bring it by.
Old 02-12-2009, 05:34 PM
nemss1's Avatar
i didnt knife-edge my blade seeing that it is really easy to screw up and not seal all the way. i wouldnt recommend knife-edging the blade. will difinitely cause probs if screwed up and is very simple to screw up
Old 02-12-2009, 09:20 PM
TireSm0ke's Avatar
Originally Posted by 12secSS
Evan,
Thanks George! I will give that a try. I just threw another code too, havent checked it yet tho
Old 02-12-2009, 11:30 PM
noriceinside's Avatar
you likely set a P0507 idle speed too high. the IAC motor is fully closed and the idle is still higher than the target idle. i had that when my LS6 intake was cracked.
Old 02-12-2009, 11:51 PM
nemss1's Avatar
^^^thats the code it would normally throw if that was the case
Quick Reply: Ported TB, now high idle.
