Question about 98' ECU
Old 09-25-2009, 02:06 AM
Chubbz155's Avatar
Default Question about 98' ECU
So I have heard that the ECU's in the 98' LS1 cars are harder to tune and are also not compatible with a lot of tuners. I have also heard of people swapping out ECU to 99'+ LS1 model ECU. So, I was wondering why the ECU is harder to tune since it is an OBDII car and has the same motor as the 99'+ models? Also what is all involved in swapping out to a 99'+ ECU if that is what needs to be done? Thanks ahead of time!
Last edited by Chubbz155; 09-25-2009 at 02:11 AM. Reason: spelled some things wrong
Old 09-27-2009, 12:37 AM
Chubbz155's Avatar
Ttt........
Old 09-27-2009, 12:54 AM
mvvette97's Avatar
not sure why they would say they are harder to tune. I have tuned many 98s and it's no different to tune than my 2000
Old 09-27-2009, 12:08 PM
Chubbz155's Avatar
Ok, so did you tune it with a hand held tuner or with a program like HP tuners?
Old 09-27-2009, 01:02 PM
mvvette97's Avatar
I used to have a superchips but now I use EFI live
Old 09-27-2009, 01:24 PM
fknsmshn's Avatar
They say its harder to tune because with HP Tuners the table resolutions are lower, and IIRC there are some options missing in the '98's. For the swap, I was told you need to repin 1 or 2 wires in the connector. Ive never heard that the '98's werent compatible with a lot of tuners tho. I've seen tuners that have the '98 listed seperatly from the '99-'02 though.
Old 09-27-2009, 03:15 PM
Chubbz155's Avatar
I have been looking for a hand held tuner to use for now before i get the car dyno tuned in a few years after a stall convertor, LT's, trans build and intake, but that wont be for probaly a year and a half to two years. If you know of a good hand held please let me know!
Old 09-27-2009, 03:46 PM
Tzion_ben_Arthur's Avatar
This thread may answer some questions.
https://ls1tech.com/forums/pcm-diagn...onversion.html
Old 09-27-2009, 11:03 PM
Chubbz155's Avatar
Thanks!
Old 09-30-2009, 12:04 AM
Chubbz155's Avatar
Ttt.......
