eibach springs in front with stock springs out back?
Old 10-25-2009, 07:16 AM
meatyz's Avatar
Default eibach springs in front with stock springs out back?
i like the ride height of the front with the eibach springs but i would like to fit a bigger tire out back i was thinking about throwing the stock springs in the rear for now has anyone done this? the car is a full bolton cam car it also has stock shocks
Old 10-25-2009, 08:18 AM
leadfoot4's Avatar
The only thing that would happen, is the rear would go back up an inch or so, I would say.....
Old 10-25-2009, 01:45 PM
BandDirector Blk98ZM6's Avatar
...or you can just do the hose mod on the stock rear springs.
Old 10-25-2009, 03:33 PM
Moderator
jimmyblue's Avatar
Be a little more rake than you see here, Hotchkiss
(-1") in front and stock w/ hose in back. Pro-kit is
a bit more drop.
With the donut, it'd be Mullet City.
Attached Thumbnails eibach springs in front with stock springs out back?-side1.jpg
Old 10-25-2009, 06:56 PM
meatyz's Avatar
hose mod?
Old 10-25-2009, 07:35 PM
Originally Posted by meatyz
hose mod?
Remove the rubber isolater at the top of the rear springs and then wrap the top coil with a hose. Lowers the rear about 1/2" - 3/4" with no adverse effects.
Old 10-26-2009, 07:39 PM
Major_Lee_Slow's Avatar
How big of a tire do you want to run in the rear? I run 315's in the rear and the car sits at 26.75 measured from the ground to the top of the fender opening. Plenty of clearance and no rubbing.
Old 10-27-2009, 08:23 AM
meatyz's Avatar
Old 10-27-2009, 08:28 AM
315-35-17
That won't be a problem. I run that exact same size, just make sure you have a while with a 50mm offset (Equal to a 7.5 inch back spacing) and then roll the rear fender lip for clearance.
Old 10-27-2009, 09:29 AM
1979rs/z28's Avatar
I have the eibach lt1 kit out front and cut stockers out back.
Old 10-27-2009, 09:36 AM
Then you might have a problem in the back, but not with tire clearance. The cut springs in the rear probably let the car bottom out way too often which adversely affects handling.
Old 10-27-2009, 10:12 AM
1979rs/z28's Avatar
I only cut a little over a half. It has bottomed out a couple times but the car was loaded with people, it hasnt when Im by myself though.
Old 11-05-2009, 11:51 PM
bigbird01's Avatar
bump anyone else know how this would look or have pics?
Quick Reply: eibach springs in front with stock springs out back?
