View Poll Results: Best Heads for Street Strip Car
TFS 220cc As Cast
9
19.15%
PRC 215cc CNC
13
27.66%
TFS 215cc CNC
25
53.19%
Voters: 47. You may not vote on this poll
Heads Choices? TFS 220,TFS 215 PRC 215?
Old 07-14-2010, 04:49 PM
1999FirehawkLS1's Avatar
Default Heads Choices? TFS 220,TFS 215 PRC 215?
Got a 99 Stock bottom end LS1 w MS4 cam kit Fast 102mm w 92mm PTM tb which would be the best head for all motor car?
Mods in SIG Thx!
Old 07-14-2010, 05:34 PM
desertLS1's Avatar
IF you have that kind of cash to throw at heads...TFS CNC 215's all the way man.
Old 07-14-2010, 05:48 PM
Detoxx03's Avatar
CNC'd Trick 215's
Old 07-14-2010, 06:17 PM
garygnu's Avatar
have you flycut the pistons ?I would go with the TFS 215cc cnc head,the the 13.5 valve angle will help with ptv clearence.
Old 07-14-2010, 09:12 PM
SOMbitch's Avatar
I have TFS/TEA massaged 220's but $$$$ no object look at Perfomance Induction... If I had the jack that would have been my choice.... Call Va. Speed they are a dealer.
You forgot AFR which is a top shelf too......
Old 07-22-2010, 03:06 AM
RUTAN TA's Avatar
TFS220 as cast
Old 07-22-2010, 12:46 PM
fatmat80's Avatar
Texas Speed has had good results with their heads, but you can not argue with TFS 215 success..My vote is TFS 215..
Old 07-22-2010, 02:25 PM
norvilleshawn's Avatar
RHS heads are prty good too. there mid flow numbers are great and thats wat u want think they might b a lil btr or less then trick flows but there cheaper and you can mill them to 37cc huge thickness very strong. i would say its one of the best heads if not the best head out thr for the money. you can take the 500 bucks you save and by smthing to make even more power.
Old 07-22-2010, 04:22 PM
Busy Mopper's Avatar
Tfs 215 cnc ftw!
Old 07-23-2010, 11:29 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
With a MS4 the PRC heads can be setup about 60cc chambers & still clear p/v for the MS4. They will also include a good spring kit so you dont have to upgrade.
With the TFS heads you'll need a spring upgrade to run that lift & best case you can mill them to about 63-64cc.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-23-2010, 03:27 PM
chrs1313's Avatar
when are you guys going to do a head battle and end all this guessing... same cc heads all top competitors, 2 different cam choices...
Old 07-23-2010, 06:35 PM
Cobra R's Avatar
Buying TFS heads from Vengeance gets the springs upgraded automatically.
TFS215 will make about 8-10 more hp than the TFS220 according to some here on LS1tech.
Old 07-24-2010, 11:46 PM
mariofromnewyork's Avatar
https://ls1tech.com/forums/dynamomet...0-results.html
I bought the 220's and got the yella terra for less than the 215s and still made great power!
Mario
Old 07-24-2010, 11:57 PM
shiv15's Avatar
My vote is for as cast 220cc with a little work by TEA. Save a ton compared to 215 and make the same power.
Old 07-25-2010, 11:25 AM
jerflash's Avatar
220 as cast FTW...best bang for buck when it comes to heads and you DONT need aftermarket rockers to make them work...ask me how i know lol
Old 07-25-2010, 01:29 PM
SSmoken's Avatar
i have tfs as cast 220's. cant wait to put them on. if my damn shim kit would ever get here. i ordered that thing 2 months ago.
Old 07-25-2010, 01:31 PM
desertLS1's Avatar
How do 220's fit with out aftermarket rockers?
Old 07-25-2010, 01:33 PM
jerflash's Avatar
dude go to your local speed shop or order these ford racing shims from jegs M-6529-A302. they work perfect and fit perfect...check out my thread hear.
https://ls1tech.com/forums/generatio...me-inside.html
all you need to get the tfs heads to work is .090 worth of shims under the stock rockers to correct geometry and in turn you need to measure for a longer pushrod. weather you go with a thicker pushrod is up to you. again check the thread and see how i did it. also get the trunion upgrade while you at it...not that hard to do with a vice and time time
Old 07-25-2010, 01:39 PM
MASS seller approved
smok'nZ's Avatar
x2
Old 07-25-2010, 01:48 PM
SSmoken's Avatar
well i already placed the order and paid. i was assuming they had them in stock. ive emailed them twice and they said they were still waiting on the pushrods to be finished.
Quick Reply: Heads Choices? TFS 220,TFS 215 PRC 215?
