How many cubes bigger can you go with a 346CI ?
Old 10-06-2010, 06:23 PM
teddyca's Avatar
Default How many cubes bigger can you go with a 346CI ?
I blew the motor in my 01Z and going to do a rebuild. Wondering if I wanted to bore over the block what is the biggest a builder can safely go with a Stock LS6 block? Do any of the vendors sell a package I could purchase for my builder with all the parts ie crank, rods, pistons, seals, bearings, etc....
Old 10-06-2010, 06:24 PM
sidewayz28's Avatar
383 with stock sleeves?? not 100% on this though
Old 10-06-2010, 06:34 PM
mike c.'s Avatar
383. Just buy an ls2 block ang you can go up. Thats what i did. BUT,my boys 383ci makes 500hp to the ground and still on a non ported intake.
Old 10-06-2010, 06:39 PM
teddyca's Avatar
Is the 383 stroked or forged ? Looking to do this on a budget. 500RWHP with milled heads, cam, and porting is my goal.
Old 10-06-2010, 06:45 PM
Always2Slow's Avatar
383 is very popular then there is the 394ish 4.125 stroke
Old 10-06-2010, 06:53 PM
DCC!!'s Avatar
well it depends do you wana use the stock crank?
you can make 383 ci with the a stroker crank and the standard bore
Old 10-06-2010, 07:09 PM
garygnu's Avatar
a ls 383 using a ls1 block has a 4" stroke crank,most likely forged.you hone the block to 3.908.
Old 10-07-2010, 09:11 AM
RsSean's Avatar
383 ls1 3.905 bore 4 stroker crank, you can do a 393 LS1 3.905 with a 4.100 stroker crank. I think you can do a 400 not quite sure on the 400. The first two I know for sure can be done.
Old 10-07-2010, 09:48 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
http://www.texas-speed.com/shop/item...d=884&catid=88
They make larger stroke cranks and correlating piston sets for that block so you could go 395ish cubic inches, but honestly if I was going to spend the extra money on a setup like that, I'd go with a different block and make it worth my time and effort!
383ci has been the long tested stand-by combo for that block, and works pretty well!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-07-2010, 10:49 AM
cdubbzz's Avatar
I have a 393ci stroker ('99 block, 4.100 stroke etc) that has 13k miles and makes 477rwhp/471rwtq...but these days you can do a newer gen style block w/ similar or less stroke and make 40+ more horsepower
Old 10-07-2010, 11:21 AM
teddyca's Avatar
At this point I am trying to determine from a cost perspective if its worth going with a 383 and using my block or just running a 402? I was trying to stay at about $4K for a long block but that is proving very tough quick.
Old 10-07-2010, 02:56 PM
DCC!!'s Avatar
i would get a shortblock from texas speed and throw there heads on as well
Quick Reply: How many cubes bigger can you go with a 346CI ?
