what's this?
Old 02-28-2011, 11:37 AM
matman88's Avatar
Default what's this?
hey guys. so I dropped my steering wheel to make my header install go smoother and it was actually pretty simple and a pretty big space maker. I went to put the wheel back in and I see this cable with a white tip marked "Up Up Up" floating around back there behind my cluster. i'm just wondering what it is because I think it might need to be replaced. here's a pic:
Old 02-28-2011, 11:41 AM
babbage1109's Avatar
looks like a bracket from the dark picture. kind of like it has a nut indentation on it but hard to say
Old 02-28-2011, 11:57 AM
96TransAmboosted's Avatar
does you car have cruise control?
Old 02-28-2011, 01:17 PM
matman88's Avatar
yeah.
Old 02-28-2011, 05:40 PM
ss.slp.ls1's Avatar
That looks like the cable that connects to the steering column on one end and the automatic shifter on the other end. I think that cable is what prevents the car from starting when it is not in park, but I am not certain.
Old 03-01-2011, 12:04 AM
marc1130's Avatar
100% positive thats the cable that prevents you from removing your key when the ignition is in any other position than off and your transmission is not in park.
Old 03-01-2011, 12:57 AM
matman88's Avatar
Thanks a lot! I've actually had trouble in the past with my key getting stuck in the ignition. any idea if it's broken or just out of place and how it goes back in?
Old 03-01-2011, 01:08 AM
Village Troll
SS RRR's Avatar
Originally Posted by matman88
hey guys. so I dropped my steering wheel to make my header install go smoother....
What headers are you installing? This is the first time I've ever read about dropping the steering shaft for a header install. Removing the steering knuckle is about all that needs to be done...
Old 03-01-2011, 01:21 AM
matman88's Avatar
Haha ya. 3 of my manifold bolts blew out... that's why i did the header install in the first place. because i get 2 new holes with headers. But I still had a bolt I needed stuck in the head flush with the surface. I dropped the wheel so I could get a 90 deg drill in there with a reverse bit but had no luck so I'm going to put it together with 5 bolts (better than 3) and see if there's a bad leak. If I get a leak I will have a shop pull the heads and drill it and tap a new hole. Whole process has been a nightmare but I'm treating it as a learning experience.
Big thanks btw for all the help. finally got them in and now I just need to finish putting everything back.
Old 03-01-2011, 01:33 AM
ss.slp.ls1's Avatar
That cable locks into the column halfway up in a black box, it's hard to describe.
Old 03-01-2011, 03:10 AM
Village Troll
SS RRR's Avatar
In all honesty it probably would've taken less time and trouble just to remove the head. Once you get the exhaust out of the way the drivers side cylinder head is cake to remove.
Old 03-01-2011, 11:31 AM
matman88's Avatar
don't you need to take off the intake manifold? I don't have the tools for that. I'm just a college kid with a Huskie tool kit lol.
Old 03-01-2011, 01:36 PM
shbox's Avatar
The cable inserts into the back of the ignition switch.
Old 03-01-2011, 04:56 PM
leadfoot4's Avatar
Other than the tool to release the fuel supply and return lines, a couple of sockets and open end wrenches are about all you need to remove the intake, and a couple more sockets and extensions get the cylinder head off. Working on a SBC is pretty straightforward...
Old 03-01-2011, 05:51 PM
matman88's Avatar
well the only write ups I've seen for top end removal are for cam swaps and say that I need to pull the water pump and balancer. do I need to do all of this if I'm not doing a cam swap but just pulling a head?
Old 03-01-2011, 06:03 PM
riceburnerZ28's Avatar
The water pump does not need to be moved there is at least one bolt that goes thru the accessory(sp?) bracket in the passengers side head that has to come out. Only basic tools are needed along with a good torque wrench. Also don't forget about the water lines thats connected on the rear of both heads.
Old 03-01-2011, 06:38 PM
matman88's Avatar
in that case I may just pull the heads and put them on a drill press. I also want to plug the EGR properly which would be easier if my intake was off.
