"Boost by gear" controllers?
I've been searching the net for a "boost by gear" solution for a near-future upgrade for my Miata swap....I'm not finding much in the way of recent/current products.
Are any of you guys using a controller similar to the old Innovative MSBC-1? I'm wanting something that reads "gear selection" based on the VSS, as the car is a 6-speed. Hell, I'd even go for an MSBC-1 IF I could find one new in the box.
Any thoughts?
Any thoughts?
eb2 can't use VSS. It has to have a 2 wire logic done by 4 switches to dictate 1-2-3-4 gear position mechanically on the shifter.
in any case, I don't think you want VSS to dictate the boost level. If you spin, the VSS goes up, boost goes up, spin more, etc. You want something independent of rear wheel speed, front wheel speed would be ideal.
AMS1000 can do it by time, VSS, or by switches also.
Any thoughts?
Any thoughts?
in any case, I don't think you want VSS to dictate the boost level. If you spin, the VSS goes up, boost goes up, spin more, etc. You want something independent of rear wheel speed.....
Thanks guys!
Interesting information with regards to the adapter....I'll check it out.
EDIT
I checked it out... Part Number: L460050000 However, I'm not sure if it could be hooked up to something like a front wheel ABS sensor. My car does not have ABS, but I could swap one of the front knuckles for one that DOES....if the PPM would be the same. I'm not sure what it would be.
I wonder if a Dakota Digital SGI-5 speedometer converter box could be used to convert an ABS sensor signal to "MPH"....interesting. The Dakota Digital DSL2 also looks promising....
But if I used a Dakota DSL2, and used it as a fake "rpm" signal output to the Eboost2....getting it's source signal from a front ABS sensor, I'm thinking it might. In said setup, low wheel speed would translate to "low rpm"....the faster the wheel speed, the higher the "rpm" that the Eboost2 would see. So...lower gears= lower boost. Higher gear/wheel speed= higher boost.
I'm open to second opinions here...am I thinking along the correct lines?
