317 OR 243 Heads LQ4
Old 03-21-2013, 06:27 PM
99TA60's Avatar
Default 317 OR 243 Heads LQ4
I currently have 317 heads on my LQ4 but I have the option to possibly get some 243 heads.. Can anyone tell me what mite be better for my application.. Like I said I am currently running LQ4 motor with 317 heads, MS3 cam shaft, Full exhaust w/ LT's, LS6 intake (I believe) and 150 shot NOS..???? Thanks
317s OR 243s????????????????????????????
Old 03-21-2013, 10:06 PM
theMOSTWANTED's Avatar
I hear great things about the 243s. I'm leaning towards the 243s for my future mods when ever I decide to do a cam and convertor swap.
Old 03-21-2013, 10:38 PM
Blackpanther99's Avatar
Ported and milled at .30 243s heads will be a great option for you. Specially since you will be spraying.
Old 03-21-2013, 11:08 PM
99TA60's Avatar
Blackpanther are you saying that the 317s are no good if im spraying or are you saying there just not as good as 243s or what...???
Old 03-22-2013, 08:47 AM
conan's Avatar
317's and 243's flow just about the same amount of air. The big differance is the cumbustion chamber size. The 243's have a 64cc combustion chamber and the 317's have a 72cc combustion chamber. So on the LQ4 with a dish piston and 317 heads it's at 9.5:1 compression. Stick on some 243's and you'll bump up to 10:1 copression range. More compression more power. 317 vs 243 one is not better than the other, it's just what is the better head for the application.
Old 03-22-2013, 11:17 AM
99TA60's Avatar
Thank you Conan you are very helpful and with that info I think Ill stick to my 317s due to the compression factor.. I eventually want to go FI so dont I want lower comp..???
Old 03-22-2013, 01:32 PM
wooddaniel's Avatar
The lower the C/R with FI the safer it is, but it really depends on the tune, the bottom end, ETC. If you are running a forged motor you can have a little higher compression ratio and still be ok.
In short, If you're planning on boosting it, I'd just keep the 317s and not spend the extra $$ for 243s.
Old 03-22-2013, 02:11 PM
99TA60's Avatar
Thank you all ill just stick w what I have.
Quick Reply: 317 OR 243 Heads LQ4
