My clutch seems to depress after spirited driving?
So I have a TR-6060, not a T-56. But I figure you guys still might know what's going on. I had an adjustable master cylinder installed, and when I drive conservatively, as in normal daily driving, it's fine. But when I have a little fun, and get pretty rough on the clutch, after a few gear changes it seems to "depress" so to speak. What I mean is, now instead of having to push in the clutch a few inches for it to engage, it's already farther back, and I only need to push it in about a 1/2 inch. It makes driving rather difficult.
However, if I turn the car off and let it sit for a while say, overnight, it drives perfectly fine again. Any idea what could be causing this?
Please read this recent thread, don't know if your pressure plate has some symptom as t56 or not but sure sounds like it:
https://ls1tech.com/forums/manual-tr...en-hittin.html
Try flushing the system out, and perhaps using DOT4 brake fluid instead. It has a higher boiling point.
Or use Motul RBF, has a BP of 500-600 instead of the generic DOT 3 which is around 300
