mushroomed intake manifold blues
I got a used intake manifold. And after receiving it I see the all the plastic around the bolt holes. Is there anyway to cut and redo this?
Sounds like someone used ft-lb instead of in-lb when installing. I would be more concerned with cracks if it was overtightened to a large degree.
Any photos of the damage? I would also contact one of the ls1tech vendors who might have some better ideas on what could be done to salvage the intake.
Moderator
I think I'd just put some washers over the mushroomed
areas. Maybe stack a hard over a rubber washer if there
isn't a nice planar surface anymore. You only need to keep
the O-rings softly compressed and the torque-down,
uniform.
uniform.
Doesn't make much
If the Drag race forum was moved to the top of the list, it would be full of unrelated threads...
Start deleting them, and maybe some would wake up, and read the stickies..
