Abs asr and brake light
Old 08-10-2014, 12:52 AM
MaroMobZ28's Avatar
Default Abs asr and brake light
How come when I get on the freeway my Asr off light, abs inop, and brake light come on ? It's weird this use to happen in my '02 but it only happened a few times. Not as much as my new car
Old 08-11-2014, 10:41 PM
Cpt.Derrek's Avatar
this can be caused by having different sized wheels on the front vs the back.
Old 08-12-2014, 02:40 AM
transwiz's Avatar
Get an abs code reader and see what code it thru. That is true about having different size wheels on front and back will cause it too.
Old 08-12-2014, 11:34 AM
LopeyZ's Avatar
Usually when all of those lights come on at once it's due to a defective ABS block(EBCM)... one located under the hood.
Old 08-12-2014, 11:39 AM
Randolph Ziskey's Avatar
Do you have stock rear??
Old 08-13-2014, 11:59 PM
MaroMobZ28's Avatar
Yes I do
Old 08-19-2014, 09:50 AM
Killer_Z's Avatar
check fuses. thats what caused mine.
Old 08-20-2014, 07:25 AM
2000 WS6 Formula's Avatar
Location: From Massapequa, New York / Now in Southern California
Originally Posted by 2000 WS6 Formula
I'm having the same issue, ABS INOP, BRAKE, and TCS OFF, lights on. Codes C0550 = ECU Malfunction Probable Cause; Failed EBCM (TCS)
& C0896 Out Of Range Voltage At The EBTCM Probable Causes; Charging system fault, Open or short circuit condition, Poor electrical connection, Failed relay condition, Ignition switch fault.
I'm the original owner and I'm at 137,000 miles. I have had the above codes come on and off for a couple of months, and have since replaced the front wheel hub assembly's that included wheel sensors, replaced alternator, and "just" cleaned the rear sensors for the first time, one had a strand of wire stuck to it (wire not in photo below).
Cleared codes, I'll have to drive it for about a week and see if codes come back, hopefully it was just the dirty rear sensors.
ABS Trouble Code Search
http://www.wellsve.com/custom_search...45&Submit.y=18
2000 F-Body DTC's
http://www.gearchatter.com/viewforum36.php
Cleaning the sensors didn't help, I'm getting the same issues. Is there any place that sells new or re-manufactured EBCM Electronic Brake Control Modules for a reasonable price?
Manufacturer: AC Delco
UPC: 707773298091
P/N 12457657 - Electronic Brake Control Module Kit
$620.75
Top three aluminum wires were broken (2nd & 3rd photo), lights would come on after engine bay got hot. I used silver epoxy, and added silicone sealant on those three wires. No problems since, You need a steady hand and a microscope to do this.
Quick Reply: Abs asr and brake light
