Accel Gen 7 vs F.A.S.T vs BIGSTUFF3
Old 12-12-2004, 12:24 PM
Boostaholic's Avatar
Default Accel Gen 7 vs F.A.S.T vs BIGSTUFF3
So I found someone last night that had a Accel Gen 7 box in their car and showed it to me, it looks like a pretty sweet setup and he claims it is much cheaper than the BIGSTUFF3 or F.A.S.T system for the LS1 while still being the same quality.
Does anyone have feedback on this?
Old 12-12-2004, 12:50 PM
qqwqeqwrqwqtq's Avatar
Well, here's my take on it.
On our shop car, we started out with an Accel Gen 7 system, and an adapter box which allowed you to keep the stock ecm in the car, and/or switch from the gen 7 to the stock ecu. Problem is, it never worked right, so we went to a stand-alone FAST system. We never tried the Gen 7 with it's own harness as a stand-alone, but there seemed to be quite a few people having problems with the system, and returning them. (Maybe that's been resolved, I don't know.)
I've always liked the FAST system, and I have one in my LT1 car, but we were having ignition issues at high rpm with the FAST system on the shop car.
Kurt at W2W informed me that the coil charge time for the FAST/edist was locked in at 4ms, whereas the stock ECU and BS3 ramps the charge time up to 6ms (max time for stock coils), as RPM's increase.
So, at that point, it was either switch to BS3, or buy two MSD DIS-4's, and 8 new MSD coils.
We switched to BS3, and it kicks *** IMHO. No more high rpm ignition issues, and alot of nice features. Not only that, but install was a breeze, as compared to the FAST, I didn't have to build the entire edist harness, or wire in a separate crank adapter box.
Old 12-12-2004, 01:01 PM
FastBlackTA's Avatar
can you keep your stock ecm in the car with BS3 (so that your gages and whatnot will all work)?
Old 12-12-2004, 01:22 PM
BLk01SS's Avatar
Ya you can keep the stock ecm with BS3.
Old 12-12-2004, 01:24 PM
The harness it comes with is stand-alone, eliminating the factory pcm and harness.
Old 12-12-2004, 01:37 PM
MIGHTYMOUSE's Avatar
i run gen7 as installed by turbotech. it works fine though i have not had experience with the others for comparison.
i run the stock computer in my car still, it still runs everything other than my cooling fans, fuel pump, ignition and injectors
Old 12-12-2004, 02:31 PM
Will the guage cluster work with this owr will I have to make my own? Sorry for the questions I'm a newbie to aftermarket stand alone management systems (going turbo sometime in the future so I'm looking into this now) Thanks!
Old 12-12-2004, 02:49 PM
I ruin the end of films...
mongse's Avatar
I think FAST's revision (XFI?) will close the gap a little between it and the BS3. It features the ability to change RPM increments at any point (rather than a set rate of 350rpm, 500rpm, etc.) I don't know about the coil charge setting. If I had more experience w/ the LSx setups, I could've asked Henninger about it this weekend.
Old 12-12-2004, 03:30 PM
GMC SKI's Avatar
I aswell would like to Keep my guages stock
Is that an option with the Big stuff??
Old 12-12-2004, 04:34 PM
Jammer's Avatar
There is currently no BS3 piggyback option available to my knowledge...this is why it was not installed in my car. I would like to beleive that if anyone put there mind to it it shouldnt be that difficult, but Id also guess there are only a hanful of people that are capable to do so with confidence. Maybe Mac or perhaps Overton knows someone. Meany has no current plans as far as Im aware. BS3 will offer a tranny controller, but if your like me, the factory gauges and the like are needed. O have seen Gen7 working with factory gauges. 24x vs 4x, I prefer BS3 for a turbo application from what I've seen for the LS1... the LS2 may offer us a better computer than the ls1 from what I have heard.
Bottom line...want over 800rw and its BS3 that appears to be rising to the top of the heap ..keep in mind that BS3's creator also was a significant cog of what became F.A.S.T. and of Accels DFI. ..he just made it with less boxes and with perhaps better, more accurate control. If Kurt uses it, you gotta think its the best out there.
Old 12-12-2004, 09:12 PM
NA$TY-TA's Avatar
I am going to go with BS3 and as from what i heard they are working on a plugin to work with the stock PCM to work with the stock PCM. If not im not worried..... ill just run a tach and go by that..... not realy worried.........
Kyle
Old 12-12-2004, 09:20 PM
2000silverbullet's Avatar
What is a BS3? Are these systems like an MSD or something???
Old 12-12-2004, 09:54 PM
427's Avatar
BS3= Big Stuff 3. It is a stand alone engine managment system that will run a LS1. It is the best box available at any price in my opionion. I have run a FAST system on LS and found it to come up short in some area's. The Accell system I have not run.
Kurt
Old 12-13-2004, 12:50 AM
BIGBOS's Avatar
Whats the official price of the BS3, I'm planning on one for next winter
Old 12-13-2004, 02:06 AM
Parker TX's Avatar
I have a gen 7 now, the other shop cars have FAST, I plan on getting BS3 for the new cars.
Old 12-13-2004, 03:53 AM
smokinHawk's Avatar
isnt BS3 cheaper then accel?
Old 12-13-2004, 07:47 AM
427's Avatar
Not sure of the price on Accel. Big Stuff 3 is 2295.00 for base LS1 kit. This includes everything you need to run a gen3 (wiring harness and ECU). The high speed Data record adds 200.00 dollars to the price.
Kurt
Old 12-13-2004, 03:24 PM
BIGBOS's Avatar
Nice, Jim how many hours did it take you to install?
Old 12-13-2004, 03:31 PM
Moderator
LIL SS's Avatar
If you were planing a full stand alone system, not using stock guages but still LS1 (My 73 Camaro) what would you use?
Old 12-13-2004, 06:07 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Well, you could potentially wire up Gen7, FAST, or BS3 into the factory stuff, and just disable some of the factory pcm inputs right. My first iteration of my FAST used the FAST for fuel but not timing. Then I went standalone. But I could have wired it up as a piggyback because I had already done stuff like add 2nd coolant temp sensor for the FAST.
Quick Reply: Accel Gen 7 vs F.A.S.T vs BIGSTUFF3
