61cc milled 20thousandths what size chamber will it be
61cc milled 20thousandths what size chamber will it be. I want about a 58cc The stock 5.3s are 61cc i have been told. Will i achieve this by milling 20 thousandths. If not how much will i have to mill to get this thanks kenny also i did a search and could not find this
Quote:
Originally Posted by DanZ28
Brent,
What's the chamber size of these heads with no milling? Trying to figure out what my CR will be..
Dan
they are close to 64cc's with no milling.
This is what I got from TEA anyway..
Brent,
Dan
Brent,
Dan
Brent,
Dan
read: https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
I have always seen the 5.3's as 61.37cc's.
From what I have read a quick way to figure out CC's after milling is every .06 you mill it equalls about 1 cc.
So if the head is milled .20 you divide it by .06 which equals 3.33
Now take 61.37 minus 3.33 and you have a new cc of 58.04.
Pretty close to what JRP got and I am sure he used a similar starting cc on the heads.
SN95 Director
I thought stock 5.3L heads where 64cc ? Since JRP didn't say anything, I guess their 61cc.
How man thousanth's to a cc JRP?
Dan
Dan
hence why i said "assuming an exact 61cc chamber", if he his heads are ported then the chamber indeed may be bigger.
Thanks for setting me straight guys .
Brent was talking about his 5.3L ported Stage 1.5 heads being 64cc with no milling. I don't think I so much took it out of context as I was more so confused at the stock chamber volume vs ported. I have read that sticky thread several times, just wanted confirmation .
Now I know and thanks again!
Dan
Dan
