need high flow cats
Moderator
Interesting question but I think the answer is none.
Stock pup-cats are funky, one-off, small and bent.
You can't fit a bigger case in where they go and all
you could do for high flow, is make a less effective
(larger passages) "brick". I believe a metallic substrate
(like many aftermarket high flow cats) would get hurt
quick, that close in to the motor (overtemp threshold
has got to be lower).
Now, you can increase the flow mightily with your
friend Mr. Crowbar but they're going to be somewhat
less effective at saving the endangered speckled
tadpole, then. Even more so than "high flow" cats.
I disagree....I have the magnaflow direct replacement cats, and they are very nice. They don't have a larger incasement than stock. They have almost twice the holes per square inch as the stock cats, and a much more fluid design. They are 50 state legal and made to pass emissions and last a long time. They fit, look and flow very well.
LS1Tech Administrator
Received 1,492 Likes
In addition to Magnaflow, Random Tech used to make an entire replacement Y-pipe for stock manifolds that also included cats (in the stock location). Not sure if that piece is still sold, probably more expensive than the magnaflow option, but if you wanted a whole aftermarket Y-pipe including cats, that would be another option.
Two words:
Random Technology
Get the 7000 series Metal Matrix ones. They good for motors producing about 550bhp.
However, unless you are changing the headers and the mid pipe there really is no point in swapping the CATS over.
Random Technology
Originally Posted by 300bhp/ton
Two words:
Random Technology
Random Technology
