ls6 ?
That's what she said...
You don't even need those if your stockers are in good shape, they are about $70 bux from the stealership for a set of 8.
But NO, you don't need gaskets.
However, you do need new coolant plugs and a front crossover pipe from a 2001+ car though. Were you aware of this?
Originally Posted by SS1875
Good point on the coolant plugs and front crossover pipe...as far as the gaskets..FAST sell's them for $32.
I couldn't find them on their website, mind pointing me in the right direction?
I made my own plugs and cross over. Took the stock coolant pipe cut the 2 back pieces off welded them and stuck on some rubber boot things just for good measure. Then cut the front of the piping so it was just 1 pipe running from the either side welded the hole of course. Although i haven't ran the car yet but it'll work.
I DID have a problem with the intake sitting flush on the heads though cause of those wires that sit under it that go to the middle of the valley. I had to peel off the tape that was holding a little black clip off those wires so the intake could sit right. Just an FYI i dunno if anyone else ever had this problem.
