ls6 ?
Old Feb 10, 2006 | 11:38 AM
GA/TA's Avatar
Default ls6 ?
Im swaping my intake to a ls6 do i need any other gaskets other that the intake port gaskets?
Old Feb 10, 2006 | 01:04 PM
TheBlurLS1's Avatar
That's what she said...
You don't even need those if your stockers are in good shape, they are about $70 bux from the stealership for a set of 8.
But NO, you don't need gaskets.
However, you do need new coolant plugs and a front crossover pipe from a 2001+ car though. Were you aware of this?
Old Feb 10, 2006 | 01:43 PM
conan's Avatar
Is the ls6 intake new? If so it will have new gaskets in it. If you need to get new ones go to a car quest they sell them for about $40.
Old Feb 10, 2006 | 04:23 PM
SS1875's Avatar
Good point on the coolant plugs and front crossover pipe...as far as the gaskets..FAST sell's them for $32.
Old Feb 12, 2006 | 11:37 PM
sebaSS99's Avatar
Cool
I couldn't find them on their website, mind pointing me in the right direction?
Old Feb 12, 2006 | 11:52 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Just give TSP a call -----------> they will help ya out
Old Feb 13, 2006 | 02:06 AM
89tang's Avatar
I made my own plugs and cross over. Took the stock coolant pipe cut the 2 back pieces off welded them and stuck on some rubber boot things just for good measure. Then cut the front of the piping so it was just 1 pipe running from the either side welded the hole of course. Although i haven't ran the car yet but it'll work.
I DID have a problem with the intake sitting flush on the heads though cause of those wires that sit under it that go to the middle of the valley. I had to peel off the tape that was holding a little black clip off those wires so the intake could sit right. Just an FYI i dunno if anyone else ever had this problem.
Old Feb 13, 2006 | 02:02 PM
GA/TA's Avatar
yeah i got everything else no the intake is not new i got it from a friend who had it laying around. Thanks for everyones reply.
