Car Shakes?
Car Shakes?
Everytime I let off the gas at a high RPM my car shakes badly, it's a vibration
that just feels bad! I was think U Joints, but please inform me on this. Thanks
1997 Chevrolet Camaro Z28 MT
Originally Posted by TAEnvy
I need one of dem dare fancy pancy aruminlum Drive shafts.
626KLZE - You might also check you're front rotors, my old setup was doing the same identical thing and everything else was fine, just the front rotors were shot, new rotors and smooth as butter.
hashtagBMW
Originally Posted by BRETTINATOR
...the aluminum ds wouldn't last the burnout box on mine...
I think thats what most LT1'ers dont understand. Its probly good for a Bolton car to go All. DS, but when you make a larger amount of power the DS becomes a bunch of peices.
Tony.
dude that **** was funny...the aluminum ds wouldn't last the burnout box on mine...
You might also want to take a look at the transmission mount. If it is a new poly one, it could not be installed correctly can be causing the vibration. I know that mine vibrated at highway speeds when I let off the gas. If its old, look into getting a new one -- and make sure you install it correctly.
Moderator
The GM 1LE is suppose to be a better unit than the stock LS1 d.s, if you had a factory warranty thats actually what they replaced the stock steel one but this was like in 01ish when the last 96-97 cars were running out of their extended warranty points. So I think its safe to safe to no one on here has any sort of warranty left.
