Dual valve spring question....
Old 08-16-2007, 11:55 PM
ws6_bandit's Avatar
Default Dual valve spring question....
I guess im not exactly sure what the difference is between single and dual valve springs. Im assuming the dual springs are rated at a higher lift?? Do they look different than single springs??
Old 08-17-2007, 07:23 AM
Viper's Avatar
A dual spring is just that, 2 springs, one coiled inside the other. They look different and are typically rated for higher lift.
shows a single on the left, dual on the right.
Old 08-17-2007, 07:42 AM
11Second Club
Gauge's Avatar
Duals add another layer of security because the chances of breaking both springs is slim. However, the inner spring is usually quite weak, so you can still very easily get P-t-V contact.
Old 08-17-2007, 07:58 AM
ws6_bandit's Avatar
I see. So the TR 230, being a "lower lift" cam, would be safe with single springs. btw its a .575/563.
Old 08-17-2007, 02:46 PM
robertbartsch's Avatar
Some single springs are safer than others!
Old 08-17-2007, 03:38 PM
GuitsBoy's Avatar
Which ones?!? Im not sure I trust any of them anymore...
Old 08-17-2007, 04:05 PM
TheLS1Kid's Avatar
^Me neither.
I'm sticking with duals.
Old 08-18-2007, 04:09 AM
njc.corp's Avatar
in aus i have witness to many single springs braking-
duals all the way after some of the things i have seen-
i would rather brake a dual than a single-
Old 08-18-2007, 07:57 AM
gillbot's Avatar
I run my TR230 on singles. The PAC springs are good.
Old 08-18-2007, 08:16 PM
Bill Bowling's Avatar
I like the duals but they do add more mass to the valve train.
Bill
Quick Reply: Dual valve spring question....
