Need suggestions on gears?
Old 01-29-2008, 06:12 PM
99w69kitt's Avatar
Default Need suggestions on gears?
What brand of 3.73 should a get gm oem or motive? Is it a good idea to go with a eaton locker for dd? All information will be appriciated.
Old 01-29-2008, 07:33 PM
austin21's Avatar
Im going to do a gear swap this spring and from the research that i have done i would go with gm oem's first but if you want to go with and after market gear go with motive . Talk to jeff at jaws about it he will get you set up ,thats were i am going......not that ,that means much ..
Old 01-29-2008, 08:14 PM
chromeplated500's Avatar
motive and richmond have my vote... People say that one or the other will make some noise... but Its all about install and break in.
Old 01-29-2008, 08:20 PM
alamantia's Avatar
Aam....
Old 01-29-2008, 08:27 PM
BOLO's Avatar
I'm running a Motive 4.10 gear installed in the stock 10 bolt. Everything is prtty quiet back there, I guess? My 3" true duals are the only ones making noise!
Old 01-29-2008, 10:17 PM
austin21's Avatar
Originally Posted by alamantia
Aam....
aam is the company that made the gm oem gears
Old 01-30-2008, 04:47 AM
EPP
EPP's Avatar
Here are the parts I carry for the 10 bolt rear. Bob
http://www.exoticperformanceplus.com...html?item=1008
Motive 10 bolt gears.
http://www.exoticperformanceplus.com...html?item=1009
10 bolt overhaul kit.
http://www.exoticperformanceplus.com...html?item=1193
10 bolt mini spool.
http://www.exoticperformanceplus.com....html?item=510
Rear end support cover.
http://www.exoticperformanceplus.com...html?item=1126
ARP stock replacement wheel studs.
http://www.exoticperformanceplus.com...html?item=1341
Moser 10 bolt axles.
http://www.exoticperformanceplus.com....html?item=162
Lower control arm relocation brackets.
Old 01-30-2008, 09:13 PM
tatasta's Avatar
+1 on Motive
Old 01-31-2008, 08:52 AM
omcar's Avatar
AAM 3.73s with an Eaton posi is a good set-up.
Old 01-31-2008, 09:54 AM
Jays00ss's Avatar
I have had Motives in My 10 bolt and now my 9" for 2 reasons, Strong and Quiet. I would highly recomend the Motive Performance.
Old 01-31-2008, 06:38 PM
99w69kitt's Avatar
change just the ring and pinion to motive gears or AAM 3.73 with Eaton posi?
99w69kitt's Avatar
