do i have all my parts for the cam swap?
Old 02-13-2008, 07:12 PM
bad6as's Avatar
Default do i have all my parts for the cam swap?
Comp 232/234 .595/.598 110+3
PRC Dual Valvesprings, seat, retainers and valve seals
New GM valve locks or keepers
Texas Speed 7.425 pushrods
LS2 timing chain
Melling 10296 oil pump
pick up tube o-ring
GM timing cover
GM water pump gaskets
GM crank bolt
GM front main seal
Ngk spark plugs
Pulley install tool
pulley remover tool
crane valvespring compresser tool
5/16" 2ft dowels for lifters
blue loctight
brake clean
antifreeze.
Old 02-13-2008, 07:55 PM
chrs1313's Avatar
get some assembly lube to put on the cam...also i would get an arp crank bolt just nice to have incase u have to take it out again...
Old 02-13-2008, 07:59 PM
01 BERGER CAMARO SS's Avatar
your good to go.
getusumws6's Avatar
I didn't see the beer listed
Old 02-13-2008, 08:03 PM
massls1guy's Avatar
Get a new O ring for the oil pump pickup. An LS2 timing chain is a good upgrade for low $$. Ls1howto has a nice list:
http://www.ls1howto.com/index.php?article=23
Old 02-13-2008, 08:07 PM
kwiksilverz28's Avatar
1. I agree with the ls2 timing chain
2. Beer should actually be number 1
Old 02-13-2008, 08:34 PM
redtail2426's Avatar
use engine oil on the cam not any assembly lube,no need for it.just extra crap inside your engine.
Old 02-14-2008, 03:42 PM
bad6as's Avatar
yea sorry i for got about the chain i have the ls2 chain
and im gonna use oil to lube the cam
Old 02-14-2008, 03:54 PM
GuitsBoy's Avatar
dont forget to brakeclean all the threads of every hole and bolt, otherwise the loctite will not grab very well, and the cam could walk. Looks like youve got everything.
