What Fuel Pumps are good..
Old 02-22-2008, 11:01 PM
LM97Z's Avatar
Default What Fuel Pumps are good..
for the price? When i do get my 97 Z down here (just bought it), i'll most likely put a 125 shot on it, i've heard the stock pump may not be enough, so i'm just wondering what some are useing?
Thanks
Old 02-22-2008, 11:31 PM
CRAZZ28's Avatar
I would go with a racetronix 255lph pump and the hotwire kit. They are on the sponsors list ------------------------------------------------->
Old 02-23-2008, 12:28 AM
Revelation Z28's Avatar
the whole kit for the price of a factory replacement, cant beat that!
+1 for racetronix
Old 02-23-2008, 08:59 AM
LM97Z's Avatar
230.00 for the whole kit, its a done deal , i've heard these pumps can supply up to 650 HP.
Old 02-23-2008, 09:03 AM
96capricemgr's Avatar
Walbro makes pretty much all the intank replacement pumps anyway so all your choices endup being Walbro. The Racetronix is the best executed kit from a fitment and upgrades standpoint so yeah it is THE choice.
I just wanted to say this before someone piped in suggesting the Granatelli or something which is the same pump anyway but nowhere near as good a value when you consider the wiring upgrades, new prefilter and all.
Old 02-23-2008, 09:36 AM
fergymoto's Avatar
Where can just the Walbro pump itself be bought without buying a kit such as Granatelli or Racetronix?
Old 02-23-2008, 10:09 AM
The stock wiring is too small so you are better off to buy the Racetronix kit with the relay harness.
I think the pump is also slightly different for a better fit.
I tried using another pump and building my own relay harness. In the end I bought the Racetronix anyway. This is one of those things where there is pretty much onl;y one good choice.
Old 02-23-2008, 10:26 AM
koolaid_kid's Avatar
You can find the pump alone. However, the wiring harness is worth the extra cost, due to its ability to deliver high current at high rpm. Once you see it, you will understand. It is truly very high quality, and very well thought out. Bite the bullet, spend the coin up front, and you will never look back.
Old 02-23-2008, 11:08 AM
Actually I bet a LOT of cars would be well served with just the wiring upgrade if the stock pump is in good condition, but I think the wiring cost a fair bit more when purchased seperately.
Think of it like the engine and the stock wiring is like stock intake tract and exhaust, opening those up allows even a stock engine to work better, same goes for the electrical supply to the fuel pump.
Old 02-23-2008, 11:26 AM
speed_demon24's Avatar
I'm running a regular walbro with the stock wiring, it handled 500+rwhp on spray with no problems...
Old 02-23-2008, 11:34 AM
Might be because you have a southern car and the wiring is likely in better shape, another varuiable that should be considered.
Then again maybe the wiring is a bigger deal on the b-bodies, couple extra feet of marginally sized wire is not going to help anything.
Old 02-23-2008, 01:11 PM
1badzee's Avatar
I just bought a Holley/Walbro 255lph for like $170
Old 02-23-2008, 02:45 PM
And for $230 you could have had a kit with a new prefilter and a very nice plug and play relay harness. You would have been better off with the Racetronix. This is exactly why I posted about how all the pumps are Walbro anyway.
Old 02-23-2008, 03:44 PM
fergymoto's Avatar
I already have a Walbro 255 in my car. I was interested in finding one for my truck. I could just get a new stock one for it but even to get the Granatelli kit just for the pump isn't that expensive.
My car is just running the stock wiring with the Walbro 255. The fuel pump went out the night I bought the car on Valentine's Day of 2005. I bought a Granatelli cause I lived close to Summit and put it in. Been running it ever since. I didn't know anything about F bodies at all back then LOL
Old 02-23-2008, 05:35 PM
BOLO's Avatar
Thanks
Walbro 255lph here. Installed when the NX kit went in.
Quick Reply: What Fuel Pumps are good..
