Electric Water Pump
Old 01-04-2009, 06:39 PM
BOLO's Avatar
Default Electric Water Pump
Thinking of replacing the stock mechanical water pump to an electric pump. Any advantages and/or disadvantages? Performance wise? BTW, no problems on the stock waterpump, just a thought of maybe changing over. Something to do over winter. Any advise appreciated. Thanks.
Old 01-04-2009, 06:56 PM
AChotrod's Avatar
I did it! Ive seen some dynos of about 10/10 rw gains and my car makes some pretty great numbers!
Old 01-04-2009, 07:00 PM
JB_97ws6TA's Avatar
Something about putting the well being of my motor in the hands of a power wire and a couple of relays just doesn't sit right. You guys can have those 10 ponys I am sticking with mechanical! I got enough electrical **** to worry about
Old 01-04-2009, 07:04 PM
AChotrod's Avatar
Mechanicals give out more than EWPs and can be changed in to minutes if it ever does. They also make a dummy light for those that dont watch there gauges alot. Plus i dont think his car is a DD.
Old 01-04-2009, 07:13 PM
zlicious94's Avatar
Been runnin mine for about two years with no problems and a nice cool motor at all times! One of the best mods I did!!
Old 01-04-2009, 07:19 PM
ABA383's Avatar
I run the Meziere on my set up and got 9-10 rwhp across the board on a Mustang Dyno. Unfortunately, I added LT headers before I got a chance to test just the EWP at the track. Because its an electric motor and turns at a constant speed you may run a bit hotter at cruise, I did, but its not bad..It does run cooler at idle and in traffic for the same reasons...I like mine and have 2 years on it...
--Alan
Old 01-04-2009, 07:43 PM
RamAir95TA's Avatar
I have a CSI with a dummy light. Cruise temps for me remained about the same and definitely provides some good gains as well as some additional benefits. I hooked mine to a toggle so that I can run the pump with the car off in the staging lanes at the track. Combined with running the cooling fans, you can cool the car down in about 10 minutes.
Old 01-04-2009, 08:23 PM
meissenation's Avatar
So if you go with an EWP, would it be best to have the switch to manually turn the fans on? I understand the mechanical water pump is going to flow better at cruising speeds whereas the EWP is going to flow better at idle. For someone that's driving to/from work or cruising on the highway, seems like adding a fan would be all that's necessary?
Old 01-04-2009, 08:45 PM
Elliott's94Z's Avatar
Well then I guess you can take pics of our rears as we go by you with our extra HP Joke
Like AC said, the stock units tend to go out more over a electric. Know of plenty of LTx owners with several thousands of miles on the EWP and no issues...including mine
Old 01-04-2009, 08:47 PM
marc97taws6's Avatar
Cheap horsepower I guess.. It all adds up.. and yes 10rwhp is a general advantage.. not sure on disadvantages as I don't have one yet
Old 01-04-2009, 08:50 PM
RamAir95TA's Avatar
I use a manual fan switch in conjunction with the PCM activation.
Old 01-04-2009, 08:54 PM
fergymoto's Avatar
No one has mentioned that if/when an electric unit goes out, it doesn't give the opti a bath.
Old 01-04-2009, 08:58 PM
Nobody ever does on these EWP threads.. at least I don't ever recall anyone saying so. So +1
Old 01-04-2009, 08:59 PM
fergymoto's Avatar
It's a very valueable benefit
Old 01-04-2009, 09:03 PM
RamAir95TA's Avatar
Also if you do convert to an electric pump, you can take out the water pump drive gear and plug the hole on the timing cover.
Old 01-04-2009, 09:06 PM
Absolutely
Old 01-04-2009, 09:19 PM
I8ASaleen's Avatar
Oh boy, I'm in b4 96capriceknowswhyyoushouldn'thaveone.
Seriously tho, buy a relayed warning system that warns for both ground and power, when the pump is getting older have a new one in the trunk and the minute you see it go out spend 15 mins. and you'll be back on the road.
Old 01-04-2009, 09:24 PM
baylove's Avatar
does anyone have a write up on installing one im interested in a ewp
Old 01-04-2009, 10:05 PM
00T/AWS6's Avatar
thanks for the info, i have been thinking about doing this for my car as well but didn't know how long they last and didn't want it to just die out on me.
Old 01-04-2009, 10:37 PM
Taubr Unit's Avatar
there cheap, just get one!! lol For once the lt1 is cheaper then a gen1 sbc, there like $350+ hahaha, SUCKERS!
Quick Reply: Electric Water Pump
